How much engine/tranny info can I pull from the OBD?
I don't want to add a bunch of permanent gauges to my Ex but I almost always have my iPhone and iPad with me, especially when towing. I've been looking at a couple of different options but I can't really find a straight answer on how much can actually be pulled from the ODB about current engine and transmission conditions on a 2002 V10. There is the Kiwi and the Dashboss and others including cheapos on eBay/Amazon.
Can anyone help shed any light?
Well the scan gauge 2 runs off of the OBD connection and that dislays oil pressure and temp, trans fluid temp, engine coolant temp, engine RPM,and more just cant think of all right now. You could look up scan gauge 2 and see what it all displays from the OBD connection.
No oil pressure or temp on the v10 obd readings.
It does show trans temp. coolant temp.
I use torque on android. Great app.
I am curious what "gauges" everyone displays on their device to monitor the engine?
I am not sure that I saw/ or got trans temp??? That's what I really need to see while towing.
I have had the scan gauge ii for awhile now. Used it n my 2000 Expedition and now use it on my 01 Excursion. It displays trans temp with no issues. This is important for towing. My opinion is there are enough distractions while driving and the ones that use your phone are a huge distraction. The scan gauge is very simple and it does an excellent job. I have had no problems at all. Easy to set up, easy to use.
