Do I need this?
Old May 6, 2013 | 09:44 PM
Hogtrapper's Avatar
Hogtrapper
Do I need this?
I have converted my '85 F250 4X4 351W over to a duraspark ingition. I am removing as much of the old ingition system as possible. I unhooked the computer from the plug and traced the wires out and removed them all except a couple of them. The 2 wires I didn't remove go to these 2 "things" My question is what are these 2 "things" and do I need them? Both of these "things" were/are mounted under the dash on the mounting bracket for the old computer. One of the wires from the old computer plug goes to the one still mounted to the bracket. There is a red wire attaching the 2 of them together. There is also 2 or 3 other wire going other places I haven't traced out yet. I would appreciate your input and you sharing your knowledge, thank you in advance.
Old May 7, 2013 | 07:28 AM
Hogtrapper's Avatar
Hogtrapper
I would still really appreciate your input gentlemen.
Old May 7, 2013 | 08:14 AM
85lebaront2's Avatar
85lebaront2
Old School Hot Rodder
I assume you probably have the 2 bbl feedback carb. I would have to look at the wiring diagram for your system. One of them is the power relay for the system, the other may be a choke heater relay, but don't know for certain.
Old May 7, 2013 | 08:22 AM
NumberDummy's Avatar
NumberDummy
Ford Parts Specialist
Both have ID numbers marked on them, post what they are. Pics too small to make them out...even w/a 27" monitor.
Old May 7, 2013 | 09:08 AM
Hogtrapper's Avatar
Hogtrapper
The numbers on this one are IMS EITF-12B514-4G13A The numbers on this one are E3UF 12A646 B2A
The truck as an after market Edelbrock high rise 4 barrell intake and an Edelbrock 4 barrell carb. The only wires on the carb are the ones I ran to hook up the electric choke. I really appreciate your input gentlemen, Thank you for your help and for sharing your knowledge.
Old May 7, 2013 | 09:18 AM
NumberDummy
Marked: E1TF-12B514-A1A or A2A or A3A = Ford part number: E1TZ-12B514-A .. Maintenance Indicator Warning Control Assy-Used to activate warning lamp to notify driver of a service requirement.
Marked: E3UF-12A646-B2A = Ford part number: E3AZ-12A646-A .. EEC Relay Assy.
Old May 7, 2013 | 09:23 AM
Archion's Avatar
Archion
Veteran: Marine Corps
In other words, yes, pull them.
Old May 7, 2013 | 10:08 AM
85lebaront2
You beat me to it.
Old May 7, 2013 | 11:04 AM
Hogtrapper's Avatar
Hogtrapper
Thank you very much for your input, it is greatly appreciated. I don't mean to be slow thinking here gentlemen I'm just being cautious. So you are saying I can remove them and throw them in the trash? Thank you again.
Old May 7, 2013 | 11:36 AM
Archion's Avatar
Archion
or sell them, give them away, there are places in these forums for that. there are people that could use those parts.
Old May 7, 2013 | 11:54 AM
Hogtrapper's Avatar
Hogtrapper
Thank you gentlemen your help and guidance is greatly appreciated. Thank you Archion, I will do my best to make them available to others, I hadn't thought about that. If someone wants them they can have them all they have to do is pay the shipping cost. Again gentlemen many thanks.
Old May 7, 2013 | 12:14 PM
Archion's Avatar
Archion
Post what you have in here...
https://www.ford-trucks.com/forums/1...good-home.html
Old May 7, 2013 | 12:39 PM
85lebaront2
It's a good place to get rid of stuff you don't need. A lot of it is NLA and people need it.
BigDaniel
Jun 11, 2017 07:47 PM
dylansf23
48
Sep 8, 2014 08:58 AM
USArmyTaterness
Electrical Systems/Wiring
Jan 20, 2014 05:08 PM
towingparts32
Feb 28, 2008 04:49 PM
LARIAT 85
Jun 20, 2007 08:43 PM
