Rear Bumper Build/Prototype
Old May 5, 2013 | 02:48 AM
Josh88Ford's Avatar
Josh88Ford
As some might know, I have been tinkering around the idea of building a custom rear bumper with a pullout storage rack. I could not find a feasable way to make it because of the two crossmembers. So with the help of a few(too many) red bull vodkas, I redrew the whole rear bumper in consideration of making this a "prototype" for fellow members due to the lack of aftermarket rear bumpers.
Front bumper build:
https://www.ford-trucks.com/forums/1...per-ideas.html
This bumper was built to directly bolt onto a stock application, with a hitch receiver. I did not find it feasable to have a "built- in" hitch receiver with the proper dot class rated hitch receivers. Therefore this bumper to built to bolt onto a "stock" application.
This bumper is drawn out for my truck. It has a hole for an aftermarket 7 pin connector on the left. the slot on the right is for a quick connect for my winch(see link)
I also tied in 4 backup lights. the two middle ones would be tied into the reverse lights, and the two corners ones would run off my f650 dash.
the two stock license plate illumiantion lights are incorporated into bumper
1" plate for 1" shackles. 1" plate would bolt directly to frame. So all pulling will be directly from frame.
suggestions, comments welcome
-JOSH
Old May 5, 2013 | 03:27 AM
A/Ox4's Avatar
A/Ox4
9 ECHO 1
Where are you located? I also have been trying to get a custom bumper. I like your design. Pretty much my ONLY requirement for my bumper is 1) Be beautiful, 2) Have a tire gate with a can holder, much like the one pictured below. The one below is the bumper I would like, but it was a one off prototype and the company hasnt returned my calls. Shame, because they are local to me. I would love to incorporate some back up lights like you have, and I love the angled idea on a switch.
Old May 5, 2013 | 03:46 AM
Josh88Ford's Avatar
Josh88Ford
PM sent Bud
Old May 5, 2013 | 05:01 AM
90pioneer's Avatar
90pioneer
Why not have a slot for the 4 pin trailer connector next to the round 7 plug? Also a hole to mount an air chuck where it would be somewhat protected would be nice for those of us with OBA.
Also don't forget about spare tire access.
Old May 5, 2013 | 10:06 AM
Tim Hodgson's Avatar
Tim Hodgson
If the vehicle you are going to put the precious bumper on is long or hard to see behind (or if you are just a bad backer upper in tight trees and places like me) you may want to consider adding aftermarket radar to that bumper like me.
Car LCD Display Parking Reverse 4 Sensors Backup Radar Price: US $21.14
Car LCD Display Parking Reverse 4 Sensors Backup Radar | eBay
The wiring to the display is delicate, but the cpu seems well made. BTW, you won't find this written anywhere, but each sensor displays individually. In other words, if the object is only or is closer on the driver's side, then driver's side sensor will only display or will display closer than the sensor on the passenger side.
[O.T. - I have doubts about backup cameras in the bumper -- I have an ebay unit I may try in the bumper for hitching. But I think I am going with a downward facing hi-def camera from the back of the van roof.]
Old May 5, 2013 | 12:59 PM
JT250's Avatar
JT250
You wanna share that cad file?
Old May 5, 2013 | 04:37 PM
Josh88Ford's Avatar
Josh88Ford
The 4 pin doesnt have a retaining bracket like the 7 pins. I'll have to dig a little deeper to see what I can do
This bumper is for my truck. All I would have to do is go back into my file, add or delete brackets and holes to fit any of the customers needs.
At this time I am not willing to share the cad file
Old May 5, 2013 | 05:23 PM
JT250's Avatar
JT250
Sell the cad file?
Old May 6, 2013 | 08:12 AM
grec-o-face's Avatar
grec-o-face
I really like the idea of two sets of back-up lights!
I agree.
Maybe use some of the same real estate as the stock plate lights. Could be a decently protected area for an air-chuck.
Old May 6, 2013 | 10:14 AM
Bossman7121's Avatar
Bossman7121
Did you do the mock up in CAD or inventor? Nice job either way.
Old May 17, 2013 | 07:32 AM
Josh88Ford's Avatar
Josh88Ford
This was drawn using Inventor, but I did have to transfer the files into a CAD so I could cut them on our cnc plasma table. I dont have any education on any of these programs, just kinda picked it up as I tinkered
Last night I got the bumper cut and bent. Tommorrow its time to start fabbing!
Old May 17, 2013 | 08:25 AM
jeffreyt's Avatar
jeffreyt
Wow, I'm very interested in how this turns out. The only change I would make is the holes for the backup sensors that are in my stock bumper.
But you mentioned a pull out storage rack... I'm assuming this would take the place of the spare correct? Slide in and out of the frame just like a kitchen drawer? Awesome idea, keep us updated.
Old May 17, 2013 | 01:58 PM
Josh88Ford's Avatar
Josh88Ford
I decided to not follow thru with my storage rack idea. There are two crossmembers and i would only have a 3-4" deep rack. And for the cost of all the cam followers, guides etc, I could not find a feasable way to build it.
There is some nice space between the body and frame by the tank filler tube. Maybe someday i'll get the ***** to cut out a square and put a box in there, just like the old 70's camper specials.
Old May 17, 2013 | 05:20 PM
itsnotanova's Avatar
itsnotanova
Color me jealous!
Old May 17, 2013 | 06:04 PM
HH60FE's Avatar
HH60FE
color me jealous too. As the kid's would say, that's mad skills, yo!
Fortworthian
Dec 14, 2023 08:54 PM
Sous
All Things Towing
Jun 20, 2018 06:12 PM
Josh88Ford
Jun 19, 2012 08:16 AM
frederic
Mar 28, 2004 08:06 AM
thewhiteford
Sep 13, 2002 11:05 AM
