Question about fuel pump access door
I would think it a more feasible solution to have a spare pump that could be plumbed into the system underhood. Disconnect the feed from the tank, and put the pump in place, connecting to the tank and to the fuel rail and power.
You could make up a quick disconnect that matches the FoMoCo snap together fuel fittings, and just use the in-tank pump as the fuel pickup. That way you can put it in place easily. Actually, I suspect you could plumb it in, and leave it unpowered and the fuel would flow right through un-bothered until you needed it.
tom
As dirt accumulates in the filter, it does what? Thats right it plugs.
And as it plugs, what happens to the pump? Thats right, it has to work harder.
And as the pump works harder, it does what? Thats right, it overheats and fails prematurely.
As for "working harder" and overheating, I'll have to disagree with that too. The pump is submerged in fuel, so it's not going to overheat. And if by some unfortunate accident the filter did get plugged, then the pump isn't going to run for very long, because the engine won't be running without fuel flowing thru the filter!
If you have enough dirt in your fuel that it's plugging up your filter abnormally quickly, then the fuel pump is going to be subject to extra wear just because it's pumping all that dirt before it even gets to the filter. That is the real hazard and the more likely cause of a pump failure. If you know that's happening then it's time to change gas stations.
I have personally experienced enough fuel pump failures to know how they behave. The #1 cause for fuel pump failures is overheating. They overheat if you let the the level in the fuel tank get too low, and they overheat if the fuel filter is becoming restricted. On a return type system, they will also overheat if the engine is getting too hot for too long.
Simple fact, if you don't replace your fuel filter when you replace the fuel pump, most manufacturers void the warranty on your new pump. Why would they do this? It is because they know that it increases the load on the pump, and that in turn makes them fail prematurely.
A factory filter has enough excess capacity to run the entire service interval, many aftermarket filters do not.
It sounds to me more like you are theorizing what causes a fuel pump failure, and you have not actually diagnosed or repaired one. I have experienced enough failures to know exactly what causes them and how to prevent them.
This whole mess of cutting a hole in the floor? In my opinion its a waste of time. If you replace the fuel filter regularly, and never let your fuel level drop below a quarter tank, your fuel pump should never fail, so having an access hole to replace it is completely unnecessary, unless you are using the junk aftermarket fuel pumps, in which case its a great idea because it will let you down.
Bob
