Need tips on fuel pump change
Old Jun 19, 2006 | 10:01 AM
duback66's Avatar
duback66
I gotta change the fule pump on my 92 f150 4X2 with the 18 gal. steel tank in the rear. Is there anything I will need besides the new pump and strainer. Also any tips would be apreciated.
Old Jun 19, 2006 | 09:56 PM
Georgia F150's Avatar
Georgia F150
OK..Just a thought...somebody said that removing the bed to get to the fuel pumps is easier than dropping them...Duback66..I'm in the same boat....Not looking forward to this job.
Old Jun 19, 2006 | 10:30 PM
brown 4x4's Avatar
brown 4x4
It's not that bad dropping the tank. The emptier the better. Every pump of this style I've done has a strainer with it. I'd recommend a pump from Ford. Although it's more expensive, some cheaper aftermarket pumps are junk, and a fuel pump isn't something too easy to change on the side of the road.
Old Jun 19, 2006 | 11:37 PM
tim73's Avatar
tim73
Ive done it both ways. Both ways by myself. When I dropped the tank I hated it. It was aggrivating and very difficult to get the lines&wires on/off. I found it easier to pull the bed off. Theres one wire warness to pull apart, then you have to loosen the gas fill neck, then theres 8 nuts holding the bed itself on. After that you can lift the bed from the side put in prybar to hold it up and you will have EASY access to the pump. The job itself will take 5 minutes. Then pull out the prybar holding the side of the bed up and lower it back into place.
Old Jun 20, 2006 | 07:13 AM
Georgia F150
I guess you would have good access to all the fuels lines from there huh...I might just do that...Anything I need to look out for? Do I need to disconnect the lights?
Old Jun 20, 2006 | 07:18 AM
Georgia F150
Concerning the PUMP. I know I've read this a hundred times on this forum. But when you ordered the parts from FORD, did they use your VIN and ENG/tranny info to determine exactly which one you needed...I've still don't know what gallon my tanks are...I always fill them when they get to empty and I only get about 14 gallons in each. I'm sure there is more than that, I'm just using the guage as a rule. Also, my 94 F150 has 170,000 miles...Should go ahead an replace both pumps? I guess thats a dumb question, they just aren't cheap. Thanks!
Old Jun 20, 2006 | 07:52 AM
mississauga's Avatar
mississauga
If you run the tank near empty that is a big help. On my 88 I unhooked the tailpipe from the hanger so I could push it to the side,and used my floor jack with one of those plastic empty milk crates on top of it to help in lowering the tank a little so I could get my hand in to remove the wire harness and fuel lines.It is tight and frustrating. If the bolts can be loosened on the box and lifted even a few inches it makes it a lot easier. But usually the box bolts are so rusted they have to be cut off and replaced,but may be worth the time.
Old Jun 20, 2006 | 11:10 AM
andym's Avatar
andym
Yeah, it depends on how rusty the underside is. If it's clean, then taking the bed off is way easier. If it's rusty, though, it's going to suck no matter which way you do it. Taking the bed off is easy. You have to unbolt the rear bumper, disconnect the one wiring harness, unbolt the fuel filler tubes, and unbolt it. I think mine only had six bolts, and it was a longbed. Taking the bed off is all but impossible with one person. I'm on the short side (5'7") and it was tough for me to lift it up high enough. My buddy is about 6'2". I'd recommend being tall if you can.
One other tip - the ring that holds the pump in place gets rusty and hitting it with a hammer is a BAD idea, because of sparks. What I do is get a pair of vise grips and grab one of the tabs and hit the vise grips with a hammer. You'll see what I mean when you get in there. I tried it a couple different ways and found that way to be the best.
Old Jun 20, 2006 | 02:27 PM
mississauga
To add, you can also use a brass drift to strike the tangs without creating a spark.
Old Jun 20, 2006 | 05:55 PM
tim73's Avatar
tim73
I have a short bed, Florida truck, so no rust here, just alot of dirt. The bed is a little heavy, I am not to tall either, but just pick up one side enough to get something to hold it up with(I used a crow bar). I didnt have to take off my bumper, only had to unhook the wiring harness(It runs along the drivers side of the frame) and hooks into the tail light wires. BTW earlier I said theres 8 nuts holding the bed on, theres actaully only 6. The bolts are weird, the holes are elongated, so the bolts are too and that makes it so they dont turn when you are loosening the nuts. If you think you will be having problems, hit it will some kroil or blaster a few hours before, both on top and from the bottom.
Old Jun 20, 2006 | 09:52 PM
bluneon's Avatar
bluneon
this is what i did. soaked it all in pb blaster and kept knocking around the whole assembly including the tank itself with the drift to knock all of the rust and crap off. i kept at it for a while until i finally saw SOMETHING that resembled a lock ring and fuel pump. cleaned it off and i bought the special fuel pump ring wrench at the parts store and the ring came right off.
Old Jun 29, 2006 | 12:18 PM
bluneon's Avatar
bluneon
i had to cut into the bolts from the top. they were seized from age when i tried loosening them from underneath. some of the nuts got stripped or the bolts themselves just spun.
how should i go about replacing those bolts? should i go to the ford dealer for 6 replacements? or could i just grab some generic ones from the hardware store?
Old Jun 29, 2006 | 02:06 PM
mississauga
I replaced my bed bolts with 1/2 grade 8 bolts ,nuts and washers. I think that 5/8 would have worked also .
Old Jun 29, 2006 | 03:26 PM
MrG4x4's Avatar
MrG4x4
I have two fuel tanks that I need to replace fuel pumps in, and pulling one bed sounds better than dropping two tanks. At least in theory.
Old Jun 29, 2006 | 03:36 PM
mississauga
I would say so. I have doing some frame work with the bed off and everthing is right in front of you. You can do the jobs standing up. Good time to check the straps especially on the side tank. Mine had rust underneath them and there was small pinholes in the tank which were not leaking enough to be noticed. Ordered a new replacement tank today.
