Comp Cams 2121 double roller timing chain set.
Old May 1, 2013 | 10:47 AM
hivoltj's Avatar
hivoltj
Anyone using it w/ the stock fuel pump eccentric? How long? Any noise/problems? It does not have the machined surface for the eccentric and the outer ring seems loose. Any help greatly appreciated, it is holding up my whole build.
http://i1214.photobucket.com/albums/...7B6E05039F.mp4
New gear from comp :
Old gear from 4,000 mile timing set that was on the truck, outer eccentric ring is just as loose on it, but it has a machined surface for the eccentric :
Old May 3, 2013 | 09:14 AM
mark a.'s Avatar
mark a.
The outer ring is supposed to be loose. There is enough for it to seat to. Always use plenty of red Loctite on the bolt and torque it to 50 foot pounds.
Old May 3, 2013 | 07:29 PM
wyoming4x4's Avatar
wyoming4x4
what mark said! good to go.
Little thrust is good. once the fuel pump arm puts pressure on it you'll never know!
Old May 6, 2013 | 05:18 PM
hivoltj's Avatar
hivoltj
Thanks guys, you should see if they'll hire ya at comp cams tech support, you're infinitely more helpful, lol. Hoping to get back on it this week.
Midnite1987
Dec 27, 2017 09:42 AM
voodoolord
May 2, 2013 10:53 PM
Eagle460
May 21, 2008 04:34 PM
Big F
Jan 11, 2007 12:22 PM
ceetwarrior
67
Apr 2, 2005 04:26 PM
