Bossman, Are you sure about that? Most all rears by 73 were 31 spline.
All 1957/72 F100 9's have 28 spline axle shafts, with one exception.
The only 31 spline 9" axles prior to 1973 were 1968/72 F100's that came with the optional heavy duty 3,600 lbs. capacity 9" with a 9 3/8" ring gear and Traction-Lok.
1973/79 F100, 1975/79 F150 9's could have either 28 or 31 spline axle shafts, as it depended on the applications.
28 spline axle shafts used 1957/67 are the same (B7TZ-4234-A) / 1968/72 is different than 1957/67 (C8TZ-4234-A) / 1973/79 is different again, and there's at least 5 different types.
1974/79 9's could have the ball type axle bearing that all 1957/73's came with, or the tapered roller bearing/seal combo. The only way to know which is present...is by pulling an axle.
1976/79 F100/150: Make sure it is a 9, because FoMoCo installed Dana 44 rear axles in some of these trucks, ratios of 2.75 or 3.00 with/without Limited Slip.
I agree with John. Whenever I do a clutch, motor change, or rear axle repair such as shadowrider is doing. I will change all the poriferals such as throw out bearings, rear axle seals and bearings, motors replace hoses, belts, anitfreeze. Just doing this when you are in there keeps you from having to come back and do it later. It can be very frustrating to have to go and do the same repair over 6 months to a year later. Ask me how I know.
jo, Im as sure as I can be without pulling an axle and counting myself that this is a 28 spline.
My plan is to remove the pumpkin out of the donor before I touch my truck so there is time for me to be 100% sure.
Plan B is to relocate the spring & shock perches on the donor rear and use the whole thing. That gives me bigger brakes and I dont have to mismatch parts.
I only paid $65 for the donor rear and it will cost me less than $50 to modify it to use in my 66.
FWIW: I used parts from a 68 to get the larger brakes on my 66. Backing plates are different & need to be swapped. Since that brake size was used through 86, it helps me keep all parts under the chassis to 76 (matching the front) when ordering.
