Wiper wrench
Old May 3, 2013 | 10:40 AM
schoo's Avatar
schoo
Wiper wrench
Improvised tool for window wiper retainer nut?
Not vice grips!
Old May 3, 2013 | 12:22 PM
66f-100's Avatar
66f-100
I see them for sale for Mustangs of the same vintage. I wonder if it is the same tool for trucks?
Old May 3, 2013 | 03:31 PM
charliemccraney's Avatar
charliemccraney
I ground a socket so that it has two tangs to engage the notches.
Old May 3, 2013 | 03:49 PM
Blackwaterforge's Avatar
Blackwaterforge
1' black iron pipe. Ground and filed ears 1/8 wide x 3/16 tall then kicked them in a bout 15 degrees.
Old May 3, 2013 | 04:35 PM
NumberDummy's Avatar
NumberDummy
Ford Parts Specialist
1964/72 F100/1100 & 1965/68 Mustang.
Old May 3, 2013 | 08:36 PM
schoo's Avatar
schoo
Used strap wrench was going to make out of pipe may still
Thanks all
Old May 4, 2013 | 03:36 AM
camperspecial65's Avatar
camperspecial65
if you have ample rags..you can wrap the pivot/nut with it and use vice grips...start with a lighter grip and see if it will turn...it being brass it will come loose pretty easily..and can be done w/o marring up the finish if you dont have the correct tool.
- cs65
Old May 4, 2013 | 08:44 AM
schoo's Avatar
schoo
The problem with metal wrench is fresh paint strap wrench is rubber and plastic
Thanks again roy
65f100pdx
Jul 31, 2019 05:00 PM
Schuby
1997 - 2003 F150
Feb 23, 2011 08:53 PM
Steve_250
Oct 28, 2005 04:22 PM
jcs1966
Dec 5, 2002 12:48 PM
