Will this rear work?
Old May 3, 2012 | 08:05 AM
earthquake68's Avatar
earthquake68
I have a 9" out of a '66 pick up. and I was going to sell the center section to a guy with a '78. Are the splines and axles the same, or are they different?
Old May 3, 2012 | 08:47 AM
NumberDummy's Avatar
NumberDummy
Ford Parts Specialist
The axleshafts are different, 1957/67 F100's use the same 28 spline axleshafts. 1968/72 F100 is different than 1957/67, could have 28 or 31 spline axleshafts. 1973/79 is different than 1968/72.
1973/79 F100's, 1975/79 F150's could have either 28 or 31 spline axleshafts.
The only way to know is to either to pull an axle, or get the axle code from the ID tag and post it here.
The other issue is the axle bearing. Some 1974/79's use the same ball type axle bearing and separate seal as 1961/73's.
Some 1974/79's have a tapered roller axle bearing/seal combination. The only way to know, is to pull an axle.
gnwatton
Oct 25, 2014 02:16 PM
Shadowrider123
May 4, 2013 08:15 AM
psquare7575
30
Oct 8, 2007 11:45 PM
OldFords
Dec 24, 2006 09:32 PM
blaxuede
Mar 28, 2002 10:31 PM
