Y pipe question
Old May 7, 2013 | 11:13 PM
Hortuna's Avatar
Hortuna
Originally Posted by ComputerCowboy
5 Star Tunes makes a Y-Pipe kit also
YPipes - 5 Star Tuning
I designed a true dual exhaust setup for mine... and my fuel economy has been climbing. The V10 does a lot better with less restriction.
I also got my y pipe from Mike at 5 Star. Installed yesterday and i haven't heard Any Flutter
Old May 8, 2013 | 09:17 AM
ComputerCowboy's Avatar
ComputerCowboy
Originally Posted by AlaskanEx
i've been wanting to do this but the flutter scares me. i'm sure i would have to put a muffler on as an annoying flutter/resonating is not what i want to hear. hmm
The flutter sound, IMHO, is caused by the crazy y-pipe design. It can really be heard when you don't have a CAT. The CAT does a lot more muffling than the muffler does.
Again, I believe the flutter sound is the exhaust gasses from each bank ramming into each-other through the stock y-pipe and forcing their way downstream from there.
Every engine will have a certain resonance with certain pipe diameters. With the V10 there are more pistons, the firing order is balanced and the frequency of the resonance is a bit higher than a V8. A V8 will generally produce a hum/drone in the 1,800-2,000 RPM area. What I have noticed about the V10 is that it sounds really angry from 2,200-2,400 RPM. If you have it straight-piped or lightly muffled with the stock y-pipe going into the stock 3" then you can hear the flutter like crazy. It is like a chewbacca gasoline hurricane as the exhaust gasses fight their way out. My dual 2.5" exhaust really smooths that all out. It revs right through that RPM range with ease now an my fuel economy has increased. I do get some drone cruising on the interstate, but that is from the mufflers. The mufflers I have are designed to change/lower the tone of the exhaust. I am going to get some Magnaflow ovals and add an x-pipe to tame it down a little bit.
Anyway. It is my understanding that the y-pipes from 5 Star or Banks are quite well tuned to prevent the exhaust gasses from fighting each-other and they promote scavenging instead.
I would highly recommend a y-pipe or any other mod that increases flow. When I chopped of my muffler, economy went up. Chopped off the CAT economy went up. Put dual pipes from the down tubes all the way back, economy went up.
The V10 likes to rev high into it's power band. The less restriction the better it will rev, simple as that. Use the power to turn the wheels not fight to push the exhaust out.
FerdF250
Feb 7, 2016 08:05 AM
crankster
Mar 30, 2008 07:55 PM
scrubby28
Feb 16, 2008 10:04 AM
Lance_I
Oct 28, 2006 03:59 PM
POLOLOUS
Exhaust Systems
Feb 25, 2005 09:06 AM
