Bigger tires
Old May 7, 2013 | 06:51 AM
Dogmann's Avatar
Dogmann
Bigger tires
Will 285's fit without rubbing on a stock 4x4 ex?
Old May 7, 2013 | 07:58 AM
jayjjcc's Avatar
jayjjcc
285/75/16 will fit fine
Old May 7, 2013 | 09:14 AM
Toreador_Diesel's Avatar
Toreador_Diesel
FTE Leadership Emeritus
You can also go as high as 305/70/16, but I think they'll rub a little....
Old May 7, 2013 | 11:18 AM
HokieHiVPI's Avatar
HokieHiVPI
Would that be solved with the standard minor trimming of the wheel well inner plastic so that the front wheels wouldn't rub when turned or is the problem bigger than that?
Old May 7, 2013 | 11:37 AM
ComputerCowboy's Avatar
ComputerCowboy
Not sure, but you might get a little spring rub which can only be solved with more negative offset or spacers. Negative offset or spacers causes more fender problems. I have 8" of lift and 315 tires on rims with -51 offset, my tires barely clear the back of the front fenders. The more negative offset you go, the bigger the radius you get on the steering.
FWIW the stock offset is +12 on a 7" wide rim, 4.5" BS
you can use the link below to enter the stock info on the left, then mess about with the numbers on the right to check clearance issues.
Custom rims, wheel tire packages for your ride - RIMSnTIRES.com
Old May 7, 2013 | 12:33 PM
Toreador_Diesel
I think it's only minor rubbing, but I don't know for sure.
My truck is 2wd and lifted 6 inches. It sits only 2 inches taller than a stock 4wd truck and clears 315/75/16 perfectly fine. So I'd figure that 305s would fit without too much rubbing.
Old May 7, 2013 | 12:49 PM
mikeswae's Avatar
mikeswae
I have 305s on my '03, 4x4, 6.0.
Highway tread didn't rub at all.
All terrains rubbed center portion of plastic wheel well only on full turn.
After about 2 weeks it wore away enough to no make noise going forward.
Still squeeks backing up.
Never took the time to trim it. Minor fix.
Old May 7, 2013 | 01:48 PM
EXv10's Avatar
EXv10
Somebody in here said the 305-70's only rub a little when turning and hitting a bump at the same time .........4WD stock.
Old May 7, 2013 | 05:37 PM
mikeswae's Avatar
mikeswae
I have stock suspension with 160k miles. Have been running this size in Firestone A/Ts for about a year. They rub whenever the wheel is turned full lock. It has worn a groove in the plastic wheel well. I only hear it when I move in reverse.
I had H/T Nittos before for about 30k with no rub. Don't buy these tires!!! They were terrible, esp in rain.
Just my experience.
Old May 8, 2013 | 11:28 AM
Mr.Nobody's Avatar
Mr.Nobody
285/75R16 on my stock EX, and there are no issues.
18wheelerfireman
Mar 4, 2015 09:20 PM
rmalottwtes30
Jul 19, 2008 11:45 PM
countryboy116
1997 - 2003 F150
May 3, 2007 03:48 PM
tonyfranciozi
Jan 19, 2007 03:31 PM
