P0299 code
Old May 4, 2013 | 12:47 PM
  #31
BLADE35's Avatar
BLADE35
Right just take off Marmon clamp at turbo the one that hold the Exhaust Pipe onto the turbo
Let it VENT There and Take those Values again and Might be Good to get ALL them at this time
BARO
MAP
EBP
EBPV
Im curious to see what Happens
Normaly a bad EBP sensor dwill give bad Value at KOEO yours is Good from what Iv seen so I just dont have the Warm Fuzzey feeling that the EBP Sensor is the Culprit YET
Old May 4, 2013 | 01:53 PM
  #32
vectrex's Avatar
vectrex
Didn't get you last post until just now. I unbolted the clamp bolts at the cat (intake) and wedged a wood shim in there to give a good 1/4 gap to vent. Numbers are pretty much the same:
RPM 0
EBP 14.9
MAP 14.6
BAR 14.6
RPM 692
EBP 18.4
EBV 1.31
MAP 14.9
RPM 1545
EBP 18.9
EBV 1.37
MAP 15.6
RPM 2495
EBP 29.7
EBV 2.20
MAP 19.4
Old May 4, 2013 | 03:35 PM
  #33
BLADE35's Avatar
BLADE35
Well its fine as long as you vented the exhaust Before the Cat and Muffler
What you get for V-Ref???
V-REF= 07E0221155 046245110655 3010 006433330000 VREF Calibration Voltage Input (Volts)
Check it with SGII
Then might not hurt to check the V-REF Signal right at the EBP sensor with a DVM In ADDITION to the SGII
In reality you could check all this with a DVM right at the EBP sensor just to rule out a Wire chaffe that might be messing the Signal up
Old May 5, 2013 | 01:01 AM
  #34
vectrex's Avatar
vectrex
V-Ref is at 5.00 volts.
I came across my notes when I bought the truck and first hooked up the scangauge. I see that my values were closer to normal then. Either the EBP has gone bad since then, or I messed it up while cleaning it when I had it out. Either way looks like a new one is in order. Whats another $80 in the grand scheme of upgraded parts I've put into it already anyways.
Local dealer wanted $120 for it. Talk about markup...
Old May 5, 2013 | 01:14 AM
  #35
BLADE35's Avatar
BLADE35
I agree everything Else checks out
See what a New EBP does
Might be good to clean Connector when you have it apart or maybe you did before IDK just a Thought
Let us know how it goes
Old May 5, 2013 | 01:16 AM
  #36
BLADE35's Avatar
BLADE35
if you have an International dealer close they are almost always cheaper there
Old May 5, 2013 | 09:00 PM
  #37
04badford's Avatar
04badford
when your in there cleaning, try the IAT2 (intake air temp) things got a little better Benny, wouldent hurt to try, cleaner with carb spray just dont hit the electrical parts and use your safty glasses that stuff burns like
Old May 8, 2013 | 06:41 PM
  #38
jedlicka87's Avatar
jedlicka87
Any updates on this? I'm curious to hear what the outcome is...
Old May 9, 2013 | 01:15 PM
  #39
vectrex's Avatar
vectrex
Not sure if you're referring to the original poster or my hijack. In my case, I've ordered a new EBP sensor from Tousley ford and expect it in any day. I also ordered the turbo mounting kit in the event I do end up pulling the turbo off for a cleaning.
Old May 11, 2013 | 03:22 PM
  #40
vectrex's Avatar
vectrex
So my EBP sensor came in today, so I'm in the process of finishing up installation. Unfortunately, I didn't get the truck up to operating temps before doing the VGT relearn, so I'm going to have to redo it.
When I was installing the new sensor, I noticed that it didnt bottom out on the mount threads completely. I'm not sure how far the old one went in, but am apprehensive about tightening it any more. I can't find any reference pics with a view of how much thread is left, so if anyone can confirm that mine is pretty well seated, I'd appreciate it.
Old May 11, 2013 | 04:36 PM
  #41
vectrex's Avatar
vectrex
So I installed the new EBP, ran through the VGT relearn procedure and took the new readings. I put the old readings in RED
RPM 0
EBP 14.8 (14.8)
EBV 0.93 (0.93)
RPM 697 (687)
EBP 17.1 (18)
EBV 1.16 (1.29)
RPM 1495 (1425)
EBP 16.7 (18.4)
EBV 1.19 (1.32)
RPM 2462 (2495)
EBP 17.9 (27.5)
EBV 1.21 (2.44)
Looks like the HI reading is a little on the low side now. Thoughts?
Old May 11, 2013 | 07:47 PM
  #42
BLADE35's Avatar
BLADE35
They Look right on Spec now
Looks OK to me FORD Spec below
Working right to left First 3 Boxes with Numbers Values
KOEO--Low Idel--High Idel
<table dir="LTR" border="1" cellSpacing="0" cellPadding="7" width="767"><tbody><tr><td height="3" vAlign="TOP" width="14%"> EP
</td><td height="3" vAlign="TOP" width="14%" colSpan="2">Exhaust Pressure
</td><td height="3" vAlign="TOP" width="14%" colSpan="2">103 (15)
</td><td height="3" vAlign="TOP" width="14%" colSpan="2">110 (16)
</td><td height="3" vAlign="TOP" width="14%" colSpan="2">55 - 607 (8 - 88)
</td><td height="3" vAlign="TOP" width="14%">kPa (PSI)
</td></tr><tr><td height="3" vAlign="TOP" width="17%" colSpan="2">EP_V
</td><td height="3" vAlign="TOP" width="17%" colSpan="2">Exhaust Pressure
</td><td height="3" vAlign="TOP" width="17%" colSpan="2">0.8
</td><td height="3" vAlign="TOP" width="17%" colSpan="2">1.2
</td><td height="3" vAlign="TOP" width="17%" colSpan="2">1.3
</td><td height="3" vAlign="TOP" width="17%" colSpan="2">0.4 - 4.7
</td></tr></tbody></table>
Does it RUN BETTER????
Old May 11, 2013 | 09:03 PM
  #43
vectrex's Avatar
vectrex
I didnt take it for a good run yet. Just drove it long enough for the VGT relearn. Will take it out shortly and open it up a bit and report back.
Old May 11, 2013 | 09:45 PM
  #44
BLADE35's Avatar
BLADE35
I bet your MPG will go UP now!!
Old May 12, 2013 | 02:51 PM
  #45
vectrex's Avatar
vectrex
Truck is running great so far. I'll have to bring it out to the grade that I was tripping the P0299 on to see if it pops up again. Thanks for your help Blade
