P0299 code
Old May 3, 2013 | 07:55 PM
BLADE35's Avatar
BLADE35
Originally Posted by vectrex
Actually, I should retake my readings since I did clean the sensor and tube while I had it out and haven't retested it. Does it matter if the truck is at operating temps?
It sounds Fine at 28psi Boost
Definatly retest Before anything Else
Its not To important for this to be at normal temp for pressure sensors But yopu must do it in Park
If I had to guess the CEL hasnt been on since the EBP Cleaning
I expect the numbers will come back better so Id Hold off on the VGT Testing and if you do endup needing that We Will get you hooked up to the Right wires +&-
Old May 3, 2013 | 07:56 PM
BLADE35's Avatar
BLADE35
Book calls 16psi for High Idel EBP
Lets see what you Got
Old May 3, 2013 | 08:14 PM
vectrex's Avatar
vectrex
RPM 0
EBP 14.8
RPM 692
EBP 18.4
RPM 1200
EBP 18.2
RPM 1500
EBP 18.5
RPM 2500
EBP 28.5
The CEL hasn't been on, but I haven't put it under load or gone on the problem grade since then.
Old May 3, 2013 | 08:19 PM
BLADE35's Avatar
BLADE35
Your Doing this In PARK or NUETRAL Right?????
If so^^^ EBP still a Bust High Idel EBP that is
Old May 3, 2013 | 08:35 PM
vectrex's Avatar
vectrex
Yup, it's in park during that test.
Old May 3, 2013 | 08:41 PM
BLADE35's Avatar
BLADE35
Can you Post EBPV
<table dir="LTR" border="1" cellSpacing="0" cellPadding="7" width="543"><tbody><tr><td height="3" vAlign="TOP" width="20%"> EP_V
</td><td height="3" vAlign="TOP" width="20%">Exhaust Pressure
</td><td height="3" vAlign="TOP" width="20%">0.8
</td><td height="3" vAlign="TOP" width="20%">1.2
</td><td height="3" vAlign="TOP" width="20%">1.3
</td></tr></tbody></table>
Here it is KOEO Low Idel High Idel
Just double check
Iv seen this a couple Times before where EBP had the Bad reading owner put New EBP in and Still had same bad numbers in the end
Old May 3, 2013 | 08:43 PM
vectrex's Avatar
vectrex
Not sure. Does the SGII read the EBP voltage on another gauge?
Old May 3, 2013 | 08:48 PM
BLADE35's Avatar
BLADE35
EP Volts (Volts)
TXD: 07E02216AE
RXF: 0462451606AE
RXD: 3010
MTH: 000100800000
NAM: EPV
And for a Double check on the SGII X-Gauge Code for SGII
Exhaust Back Pressure
TXD: 07E0221445
RXF: 046285140645
RXD: 3010
MTH: 001D00500000
NAM: EBP
KO=103 (15) LI=110 (16) HI=110 (16) OR=55 - 607 (8 -88) kPA (PSI)
Old May 3, 2013 | 09:07 PM
vectrex's Avatar
vectrex
RPM 0
EBP 14.8
EBV 0.93
RPM 687
EBP 18
EBV 1.29
RPM 1207
EBP 17.9
EBV 1.28
RPM 1425
EBP 18.4
EBV 1.32
RPM 2495
EBP 27.5
EBV 2.44
EBP settings look right in the SG.
What is this: "KO=103 (15) LI=110 (16) HI=110 (16) OR=55 - 607 (8 -88) kPA (PSI)"?
Old May 3, 2013 | 10:04 PM
BLADE35's Avatar
BLADE35
RPM 0
EBP 14.8
EBV 0.93
RPM 687
EBP 18
EBV 1.29
RPM 1207
EBP 17.9
EBV 1.28
RPM 1425
EBP 18.4
EBV 1.32
RPM 2495
EBP 27.5
EBV 2.44
Thats the Ford Spec^^ For EBP KPA (PSI)
KO=KOEO
LI=Low Idel
HI=High Idel
OR=Operating range
Safe to say EBP is Off at high Idel
Old May 3, 2013 | 10:31 PM
vectrex's Avatar
vectrex
So ford defines high idle as 2500 RPMS?
Guess I'm in for a new EBP sensor. Looks pricey already.
Old May 3, 2013 | 10:44 PM
BLADE35's Avatar
BLADE35
Yes 2500rpm high Idel
Basicaly the way we test is just in a way that can be replicated from one truck to the next and one set numbers work for everyone with Stock Programming
Your Not running a tunner are you??????
as far as EBP it does Look bad But remember Iv seen this 2 times before and New EBP Sensor DID NOT FIX
So we have to Look at the Possiblity that HIGH EBP reading IS TRUE and at this Point have to Rule Out a Plugged Exhaust
Do you have the Cat and Muffler??
Tommorrow Losen the Marmon Clamp at the Downpipe and rerun Numbers
Old May 3, 2013 | 10:50 PM
  #28
vectrex's Avatar
vectrex
Stock truck. Passed emissions here in Cali, so I imagine all the parts are still there.
Old May 3, 2013 | 10:54 PM
  #29
BLADE35's Avatar
BLADE35
When I say Iv seen this 2 times Before I Mean EXACTLY same as YOU
Test the Truck EBP Numbers Look Good at KOEO and Low Idel All the way till High Idel then BAM hit high idel and EBP High Idel Numbers were Really High
These Guys change the EBP sensor and Still had Issues
So Im just trying to explore ALL Possibilities and save you a Buck or two
Plus I HATE thrown Parts
Old May 3, 2013 | 11:24 PM
  #30
vectrex's Avatar
vectrex
Right. Well thanks for your help with this. I'll look at disconnecting the exhaust tomorrow. Been thinking about a cat delete anyways, might be time for that. I can always shelf the cat for emissions testing purposes.
