Key-on power under dash?
Old May 2, 2013 | 12:05 PM
kell104's Avatar
kell104
Are there any sources of Key-on power under the dash that don't require splicing into factory wires? The PO of my truck installed the gauges and just had the power wire jammed into the fuse box along side a fuse and it is bothering me to have it that way. Some vehicles used to have some spots in the fuse boxes where one could hook up additional equipment but I don't see anything here. Just wondering what others are using to power up their gauges and equipment.
Old May 2, 2013 | 12:16 PM
ronjon95's Avatar
ronjon95
I do not believe there is. The PO did the same on my Truck. I could not stand it either. I Tapped into the Parking Light wire at the Head light switch. That way the lights are only on when the parking lights and or the head lights are on. You wouldn't need the gauges lit up during the day anyways. Just use wire strippers not cutting the wire and pull back the insulation about a 1/4" split the wires run the gauge light wire threw then solder, wrap with black tape very well and be done. Or are you looking for power for the Pyro EGT gauge?
Old May 2, 2013 | 12:28 PM
snakedoc's Avatar
snakedoc
there is a green wire (it may have a yellow strip) under the dash near the gas pedal that should be taped off, it has 12v with key on.
Justin@DP-Tuner's Avatar
Justin@DP-Tuner
PREMIUM SPONSOR
Go get a fuse tap from the local auto parts store. That is what most do when installing gauges.
__________________
Justin
Like us on Facebook!
www.dp-tuner.com
Old May 2, 2013 | 12:44 PM
JOHN2001's Avatar
JOHN2001
This is what I was planning to do because the wire I ran to the battery is driving me crazy!! What fuse is a constant source? And what one is a ko?
Old May 2, 2013 | 12:46 PM
kell104's Avatar
kell104
I got the guage lights fixed by using the extra wire on the trailer brake controller adapter harness. IT was labeled as "illumination" and was taped off before going into the controller. I am looking to power the gauge itself.
Old May 2, 2013 | 12:47 PM
kell104's Avatar
kell104
I'll look for that, good tip!
Old May 2, 2013 | 12:54 PM
Justin@DP-Tuner
PREMIUM SPONSOR
Off the top of my head, I am not sure. Look in the owners manual for what all the fuses go to, and then get a multi-meter to check if it is constant or KO.
__________________
Justin
www.dp-tuner.com
Old May 2, 2013 | 12:59 PM
riley431's Avatar
riley431
I need to do this also. After a certain place put in my auto start. The gauge lights are wacky. And my EGT and TRAN. Temp don't work.
Old May 2, 2013 | 02:07 PM
Shake-N-Bake's Avatar
Shake-N-Bake
I will try and post a pic that will help. Depending on the model year...you should look for a light blue wire with pink stripe or a white wire with blue stripe
https://www.ford-trucks.com/forums/attachment.php?attachmentid=53131&d=1334183825
Old May 2, 2013 | 03:44 PM
dn29626's Avatar
dn29626
Old May 2, 2013 | 04:05 PM
90pioneer's Avatar
90pioneer
BAD IDEA, REPEAT, BAD IDEA!!!!!
I just went through this.. if you get a fuse tap you run the risk of breaking the fuse contacts inside the fuse box which you shove it back in. This literally happened to me last week. It cost me $80 to have a shop solder in an inline fuse to make a repair.
You can go with an "add a circuit" but DO NOT go with a fuse tap!
Old May 3, 2013 | 12:51 AM
Justin@DP-Tuner
PREMIUM SPONSOR
Cooper Bussmann/ATM fuse tap (BP-HHH-RP) | | AutoZone.com
That is what I meant by fuse tap. That is what the package lists them as.
__________________
Justin
www.dp-tuner.com
Old May 3, 2013 | 12:55 AM
90pioneer's Avatar
90pioneer
Okay good... those are typically called "add a circuits"
here is what you DON'T want to use:
Dorman/Fuse power taps kit (85606) | Fuse and Accessories | AutoZone.com
Cooter55
May 2, 2018 06:49 PM
Steve_250
25
Jun 28, 2005 04:56 PM
edub32
13
Jun 13, 2005 10:54 AM
cjcathey2002
Apr 20, 2005 06:42 AM
josho66
Electrical Systems/Wiring
May 16, 2003 01:15 PM
