Detonation
Old May 1, 2013 | 09:09 PM
Bovaloe's Avatar
Bovaloe
Detonation
1991 F150, 351w, MAF swap, A9L ECU, 0.030" over, stock style pistons, GT40 heads, performer truck upper and lower intake, timing set at 10* BTDC, about 10,000 miles on engin, no CEL.
Started having a detonation problem under load, basically any hill would make it start pinging like crazy. Went home set the timing back to 10*, drove it easy, figured bad gas maybe. Filled it up with front tank full of 91 octane, still did it, didn't seem to do it as much as on 87 though.
Only thing I wasn't sure about was when I set the timing, put the spout back in and revved it a bit, timing shot up to past the marks on the harmonic balancer, maybe 40* or so, about 20ish warm idle. Is that normal? Just to clarify, spout out, turn on, set timing, turn off, spout back in, rev up.
What else could be causing it? I've been running on cheap gas since I built it, no problems with detonation until now.
Old May 1, 2013 | 09:19 PM
Encho's Avatar
Encho
The Southernmost Mod
Which sparkplugs are you using? what's their gapping? did you remove the SPOUT before you set the timing to 10°BTDC? Do you have a fresh/good coil?. If none of those are the causes then something is loose inside the engine (even more possible if the engine was recently rebuilt), I would take the valve covers off as a starting point.
Apparently you did disconnect the SPOUT, so cross that one out.
Old May 1, 2013 | 10:31 PM
Bovaloe's Avatar
Bovaloe
Autolite coppers, 0.044", not sure on coil, doesn't sound like something rattling around, it has no problems on flat ground, I can get on it good, just with a hill or really lugging it in 5th, that sort of thing.
How would a bad coil cause detonation?
Old May 1, 2013 | 11:04 PM
Encho's Avatar
Encho
The power of the spark depends directly of the coil, but I would be checking the entire ignition system.
Old May 2, 2013 | 07:39 AM
White Max's Avatar
White Max
Bovaloe, are you running an oiled air filter (like a K&N)? When was the last time the fuel filter was changed? The ignition advance you saw while revving the engine with the SPOUT in is normal.
Old May 2, 2013 | 08:06 AM
Conanski's Avatar
Conanski
Check for crossfire between plug wires, these motors should never ping at 10deg maybe a couple wires are a little too close.
Old May 2, 2013 | 09:25 AM
Bovaloe's Avatar
Bovaloe
Yes I'm running a k&n, haven't checked it in awhile, dirty air filter maybe?
Just swapped in a paper one, at work didn't have my cleaning stuff for the k&n.
Fuel filter hasn't been changed in awhile either, can't remember, bought one too,swap it on my lunch.
Wires are touching in places but they're only a few months old.
Old May 2, 2013 | 09:58 AM
Conanski's Avatar
Conanski
Fire it up in the pitch dark with all the vehicle lights off and rev the motor, you'll soon see if there are any cross firing issues.
Old May 2, 2013 | 10:46 AM
White Max's Avatar
White Max
Clean the MAF. Oil from the air filter will collect on the MAF sensor, which throws off both fueling and ignition advance, as the EEC uses the MAF to calculate both the air charge and load. Cleaning the MAF becomes part of your standard maintenance when running an oiled air filter, and if you've gone 10K miles without cleaning it, I bet it's the source of your issue.
The fuel filter probably isn't the source of the problem, unless it's getting clogged/restrictive, but it certainly wouldn't hurt to change it and rule that out.
Old May 2, 2013 | 12:17 PM
Bovaloe's Avatar
Bovaloe
Thanks for the replies
I'll check for cross fire tonight, and clean the MAF in my lunch when I change my fuel filter.
Hopefully it will solve the problem.
Old May 3, 2013 | 01:04 AM
Bovaloe's Avatar
Bovaloe
Ok, so changed the fuel filter, sorted disney on the MAF, checked for cross fire (none).
Still pinging, no change at all.
Put some more 91 octane in, had an STP fuel system cleaner, the seafoam looking bottle, so I threw that in too, figured it couldn't hurt.
What other things can I check for?
Old May 3, 2013 | 08:15 AM
White Max's Avatar
White Max
What did you do to the MAF?
Old May 3, 2013 | 09:19 AM
Encho's Avatar
Encho
Didn't you read? he sorted Disney on it... whatever that means...
Old May 3, 2013 | 09:45 AM
White 97 xlt's Avatar
White 97 xlt
Old May 3, 2013 | 10:13 AM
rla2005's Avatar
rla2005
Originally Posted by White 97 xlt
You are sooooooo bad............
