throttle position sensor?
Old Apr 30, 2013 | 08:54 PM
Shade's Avatar
Shade
Hey guys is there a cheaper fix for the pedal mounted throtle position sensor than $200 from the factory? Mine is an 03 6 speed with non adjustable pedal and has started to go bad, I have a hard time making myself pay that much for a pedal sensor. Thanks for any help
Old Apr 30, 2013 | 09:10 PM
tfdcapt's Avatar
tfdcapt
i have a 2000 super duty and have replaced my throttle position sensor at least 4 or 5 times. I have gotten mine at NAPA for about 40 dollars. The dealer will tell you that you have to replace the whole pedal assembly but if it is like mine the sensor will come off. Mine is attached with two torx screws and takes about 10 min to replace hope this helps
Old May 1, 2013 | 09:11 AM
01PS's Avatar
01PS
Try spraying some contact cleaner in it.
Old May 1, 2013 | 11:10 AM
F250_'s Avatar
F250_
There are two types of non-adjustable throttle pedal sensors. One has the removeable sensor as described above in Post #2, and the other has the sensor module actually built into the entire pedal assembly (like mine is). IIRC, I purchased mine from Ed when he was still around (a Ford Parts Dealer in Washington State), but would now go to Tousley Ford because they are a sponsor and have the best dealer prices you can find.
Potentially helpful old threads...
https://www.ford-trucks.com/forums/9...ml#post8675168
https://www.ford-trucks.com/forums/1...ealership.html
https://www.ford-trucks.com/forums/9...tor-pedal.html
TOUSLEY Ford Link... Tousley Ford Parts Depot
Old May 4, 2013 | 01:25 AM
Shade's Avatar
Shade
Thanks guys, I have the built in one that cant' be changed individually. Fortunately I also have an old friend at a local dealer so she got me the wholesale price that ended up being 160 instead of 200. I hate paying that much for something that should cost about 40 though.
Old May 4, 2013 | 07:23 PM
F250_'s Avatar
F250_
Wow... the Dorman replacement pedal assembly, complete with the new sensor, is only $71 from Rock Auto
2002 FORD F-250 SUPER DUTY Accelerator Pedal
Franko72
Apr 27, 2011 09:36 PM
bigbubba87
38
Dec 13, 2010 07:42 AM
bigbubba87
32
Apr 15, 2010 08:21 PM
lincolntech8105
Aug 3, 2007 11:48 AM
