Also, does it make sense to put a shut off on one or both sides of the housing?
Shut offs aren't necessary. Most of the oil in the housing should drain back into the block thru the line and there only be oil held in the filter itself with it being mounted upright.
It was cut from a piece of 1/4. No welding, just a lot of scribing and a little sawzall work. I'm a carpenter not a welder so its kind of crude.
[IMG][/IMG]
From the look of the pic, it appears as though, with a "wider" piece of metal, you could have done away with the "mailbox flag" look, and went to a more of a "7" look, based on, you using the top mounting hole for install.
