power steering pulley
Old Apr 30, 2013 | 02:28 PM
soonerjeepman's Avatar
soonerjeepman
Was just replacing line to steering box off of pump, but could NOT get it loose from any direction so I took the whole pump off. Prob just replace pump as well..since it's off but want to keep pulley to put on new pump. Looks like a T? and not sure how to take pulley off. I've searched on-line but no use. I guess if a new pulley is only $10 I'll just get a new pulley as well.
Any help would be great..
Thanks
SJM
off of a 350E van
Old Apr 30, 2013 | 02:33 PM
Talyn's Avatar
Talyn
You need a puller for it, its a press on part.
You can usually rent them.
It will have a coupler that fits over top of that lip then a collar fits over it and you just crank the nut while holding the bolt and it will pull right off. To put it on, you reverse the process. Just thread the threaded end into the end of the pump and crank.
Mine that I purchased is a puller only, so I used a bolt and some injenuity and pressed it back on with some washers.
Works on the vacuum pump as well.
It's a cheap tool set vs some other sets like a ball joint kit.
Old Apr 30, 2013 | 02:45 PM
ReBilld's Avatar
ReBilld
This is the one I have......Performance W87020 Power Steering Pump and Alternator Pulley Puller | Performance Tool Shop
Here is the installation tool....http://www.summitracing.com/parts/wm...FYYw4AodUzMApg
Old Apr 30, 2013 | 08:05 PM
soonerjeepman
Ok, thanks for the info.
SJM
Old Apr 30, 2013 | 11:04 PM
oldbird1965's Avatar
oldbird1965
Most auto part stores will loan you those tools.
Old May 1, 2013 | 06:30 AM
OldWoodsDiesel's Avatar
OldWoodsDiesel
I changed my pulley without a puller if you're looking to save a few bucks/minutes.
1. put a ~1.5" long 3/8-16 screw into the threads in the old pump shaft.
2. support the HUB of the pulley with the jaws of a vise - don't clamp it, just set it on top with the jaws set to the right width. and make sure your supporting the hub and not the outer rim, otherwise you could bend the pulley. the body of the pump should be hanging down through the vise, with the screw you put in facing up. you'll have to hold the body of the pump with one hand to keep the pulley oriented flat on the vise jaws.
3. tap on the head of the screw with a small hammer until the pump is free from the pulley
4. remove the screw from the old pump shaft to completely free the pulley.
then, to put the pulley on the new pump, use the same 3/8-16 screw and a bunch of washers to pull the pulley on. you may need a few different length screws, or a big stack of washers. you just turn the screw until the pulley is seated right. there'll be a very slight step on the pump shaft that the pulley seats against. DO NOT HAMMER THE PULLEY ON or you'll be buying another new pump!
took me about 10 mins to swap the pulley over this way - faster than I can drive to the parts store since I had ordered the pump by mail :-)
Old May 1, 2013 | 10:29 AM
soonerjeepman
cool...thanks, I'll def try that first.
Really appreciate the info.
SJM
Old May 1, 2013 | 11:27 AM
Talyn's Avatar
Talyn
The puller is worth having, you'll need it again if you keep the stock vacuum system. The pumps like to go out occasionally.
JHoffman93
Oct 3, 2016 11:31 AM
octaneforce
Jan 24, 2015 12:19 PM
TurboTuff
19
Mar 13, 2013 11:40 AM
cdorroh
23
Mar 28, 2005 10:48 AM
OneFine69
Dec 24, 2003 08:25 AM
