94 F150 I6 Hard Start Problem
Old Apr 29, 2013 | 10:08 PM
droff85's Avatar
droff85
Ok I am working on my uncles 94 F150. I have two major problems that I can't get figured out.
1. A couple of weeks ago he contacted me about his truck not wanting to start. After I looked it over I cleaned the throttle body and IAC. The truck started cranking fine. Last week he called and said that it was acting up again. Now when you go to crank the truck the engine will spin over but won't start unless you mash the gas pedal all the way to the floor. When it does crank it blows black smoke out the tail pipe and runs rough for a few seconds. It also blows black smoke when revved. I found the distributor cap had some corrsion on the contacts and the plugs were very black. I also found that the post on the coil had been eaten away from arcing. So I replaced the plugs, wires, cap, rotor, coil and even the pickup coil in the distributor. I also cleaned the injectors and am still having the hard start problem with black smoke.
2. I have a scanner from the local chain parts store that will read the codes on an EEC-IV Ford system but mine is not communicating with the computer. Is there a fuse or something that would cause the plugs not to work? Or is my scanner just not communicating for some reason?
Sorry for the long post but I was trying to be very informative. Thanks in advance for any advice.
droff85
Old Apr 30, 2013 | 01:18 AM
tiap's Avatar
tiap
Sounds like at least one bad injector causing the rich condition. At least bleeding off when shut down.
Old Apr 30, 2013 | 11:48 AM
Truckin Bob's Avatar
Truckin Bob
droff85
Does the fuel pump run for 1-2 seconds (prime) then shut off when the key is turned to the "on" position, or do they/it run continiously ????
To me, it sounds like you've got a PCM that's failing........
Here's a link of what "could be" going on.
Click here:A9x ECM's (and same years ECM's) Failures Due to Age
"If" the grounding circuits within the PCM are or have been corrupted by capacitor leaking/failure, the PCM "could" fail to communicate with a code reader/scanner, no/random grounding of injector pulse rate(s), inability to store trouble codes, random missfires/stalling, flooding problems......just to name a few things.
And if you like to read, this poster (Guy) had the problem of his PCM not communicating with his scanner. https://www.ford-trucks.com/forums/1...st-module.html
I'd try removing the PCM and give it a look inside.
If everything looks good inside (no capacitor leakage/burnt components) then go from there.
To me, based upon your symptoms, that's where I'd start.
And, my 94' PCM had the capacitor leaking problem.
It took a few bucks and a visit to Radio Shack to repair mine.
Bob
Old Apr 30, 2013 | 07:35 PM
droff85's Avatar
droff85
Ok figured something interesting out this afternoon. I had to move the truck and when I cranked it everything was fine but the check engine light was on. I decided to take the truck down the road and once I noticed the thermostat opening, showing movement on the temp gauge, the check engine light went off and the engine started showing the black smoke again. I decided to shut it off and try cranking it again and the hard star was present again. While it was cold it started right up with no black smoke. Does this help?
Old May 6, 2013 | 10:18 PM
droff85's Avatar
droff85
Anybody got anymore advice? I read on another thread about checking the coolant sensor. Would this be something to look at? And if so what am I looking for exactly?
Boger
Oct 2, 2021 10:32 AM
xech0x
Modular V8 (4.6L, 5.4L)
Apr 10, 2013 07:24 AM
KCGman
May 2, 2011 08:56 AM
the winemaker
Oct 18, 2010 07:24 PM
17fordguy
Sep 25, 2009 05:31 PM
