Checking Points
Old Apr 29, 2013 | 07:40 PM
ffillah's Avatar
ffillah
Checking Points
The ole girl has been sputtering a bit in 3rd gear and I'm thinking it could be the points. I've never messed with points before and I'm having trouble trying to figure out what the right setting is. I just got some feeler gauges and I've read online that maybe 0.017 is the right setting. Is that right for a 352fe?
Old Apr 29, 2013 | 07:55 PM
1972RedNeck's Avatar
1972RedNeck
After a while you just kinda look at it and go "eh, that's about right" and tighten it down.
.017" is correct.
Old Apr 29, 2013 | 08:21 PM
Tedster9's Avatar
Tedster9
The trick is, ya hafta have the rubbing block juust set at the top of any one of the lobes on the dist. Don't try to file them unless you know how, but you can take a clean, new dollar bill and use that as an abrasive material and drag it through the closed points, saturated with non-residue solvent like naptha or carb cleaner.
bigb56
Jul 16, 2017 11:05 PM
HappyJack
Kansas Chapter
16
Mar 4, 2008 07:56 PM
59'er F100
Apr 18, 2005 09:24 PM
