Engine running WIDE OPEN
Old Apr 28, 2013 | 08:20 PM
Tommky's Avatar
Tommky
I need help please. I have a 1986 F-150 302 with EFI. Cleaned throttle body which was gunked up very bad. Very few items to remove to disconnect body to clean it so very little was done. Excited about running it after cleaning to see if runs any better. To my amazement, engine revs wide open with RPM needle pegging out. Have to turn ignition off immediately as fear of blowing it.
Unhooked battery for 30+ minutes hoping it was some kind of memory setting. No change. Also unplugged Air Bypass valve, no change. Butterflies seem to move easily with no binding. What in the world could I have done that would cause engine to rev to max? Please share ideas if you have any.
Thanks
Old Apr 28, 2013 | 08:36 PM
ctubutis's Avatar
ctubutis
I would guess you installed the throttle body and/or linkage incorrectly.
Can you operate the linkage by hand under the hood and visually see what it's doing? Begin there.
Old Apr 28, 2013 | 09:12 PM
Tommky's Avatar
Tommky
We didn't really disconnect the linkage, just laid it back. I took the two bolts loose that holds the linkage to the top of the intake manifold. The butterflies move manually and when applying the accelerator. The butterflies are about 90% closed with the engine off. Is that where you would expect them to be? As you apply the accelerator, the become more open. That would be how they should move isn't it? I have not tried to see if they move when starting the engine as it is revving so high.
Old Apr 28, 2013 | 09:17 PM
Rico47635's Avatar
Rico47635
The throttle is either stuck open or the butterflies have broken loose and been sucked into the intake. I've had both happen before, but fortunately only once with the butterflies getting sucked into the engine. Hope you get it figured out.
Old Apr 28, 2013 | 09:39 PM
ctubutis's Avatar
ctubutis
"Giving it gas" means opening the throttle, which means allowing the engine to suck in more air and more gasoline.
Yes, throttle plates opening up once the engine is running can cause this problem.
I'm sorry, didn't mean you should have the engine running when you look at the operation of the linkage and plates....
Old Apr 29, 2013 | 07:42 PM
Tommky's Avatar
Tommky
Problem Solved
Thanks
Thanks to everyone for your helpful comments. The problem was due to the butterfly plates not being reinstalled properly. They would rotate but only so far. They could not fully close and that was the main problem in causing it to rev wide open. Several of you made comments that were very close and it just took another close look to figure it out.
My son has been driving the truck and he is the real enthusiast, just not having the knowledge and experience to take on cleaning the gunk out of the throttle body. After the project "blew up" I had to try and learn how it worked. We had a nice discussion on lessons learned.
- ctubutis - you were on it right out of the gate - thanks
Thanks again.
Old Apr 29, 2013 | 08:54 PM
ctubutis's Avatar
ctubutis
Thanks for the update, all too often we don't hear the outcome or know if we helped or not....
Old Apr 29, 2013 | 09:02 PM
Tommky's Avatar
Tommky
This was my first time to use the forum. I plan to use it more especially now that i have a "story."
Johny Maschinko
2004 - 2008 F150
Mar 18, 2012 02:32 PM
Lobo
Dec 31, 2007 09:42 AM
F-250 diesel
1997 - 2003 F150
Jan 23, 2007 11:00 AM
Richardson
15
Sep 21, 2004 01:19 PM
budda919
1978 - 1996 Big Bronco
Oct 3, 2003 06:16 PM
