Flathead parts - Whatca Think
Old Apr 28, 2013 | 07:20 PM
4tl8ford's Avatar
4tl8ford
I'm going tomorrow to look at the following - The guy's asking $600
Up for sale is an 8BA Ford flathead block,
2 sets of heads,
2 crankshafts,
2 oilpumps,
1 oilpan, with large clean out plate on bottom,
oil filter canister that mounts to rear of leftside head,
3 transmissions, two are top loaders, one is a side loader,
2 fans, one 4 blade, one 6 blade,
1 complete starter,
1 flywheel, with pressure plate and clutch plate,
a set of connecting rods,
4 water pumps,
starter plate,
1 offenhauser 2 duece aluminum intake manifold.
Many other misc. parts,
extra main caps,
thermostat housings,
timing cover, cam,
stock intake manifold,
exhaust manifolds,
road draft tube,
oem oil fill cap, the big one.
Old Apr 28, 2013 | 07:53 PM
ALBUQ F-1's Avatar
ALBUQ F-1
I'd be suspicious why its all apart and for sale? Is it one engine that's disassembled, plus parts from others? Are the valves, guides, and springs included? Sounds like a cracked block was found and rebuild abandoned. As far as selling it off as parts, not a lot of demand except if the block is good. If it's a complete engine and not all rusty and cracked, you could have it rebuilt and either use it or sell it, but don't expect to get rich. Lucky to break even. The price is a little high except that the trannies and Offie manifold probably bring it up to just about his price.
Old Apr 28, 2013 | 07:56 PM
tinman52's Avatar
tinman52
Welder User
If you are wanting to build the motor and need all of those misc parts, then go for it. They don't have a lot of value otherwise. Depends on condition of course, but I don't think that price is too far out of line. Make sure to look it over closely...
Old Apr 30, 2013 | 07:15 AM
jmadsen's Avatar
jmadsen
Hey. That sounds like my garage!. Ive got at least 6 of everything which is six times too many. if the trans are 3 speeds your good to go.
Old Apr 30, 2013 | 07:29 AM
Doc's Avatar
Doc
A deciding factor in my opinion would be those transmissions. Get some more info about them. The light duty 3-speeds are in pretty big demand here nowadays, and they're not exactly falling off trees.
bhalemail
Sep 17, 2017 07:24 PM
r_reed
Ford Truck Parts for Sale
Nov 6, 2014 09:54 PM
jat4
23
Jul 22, 2011 10:46 AM
tip49
May 19, 2005 08:11 AM
59'er F100
Jan 14, 2005 12:55 PM
