Ot Mercon v question.
Old Apr 28, 2013 | 01:40 PM
Crewcab Turbo's Avatar
Crewcab Turbo
I have a friend whose father has a Jeep Grand Cherrokee with a automatic transmission. He got some water in his Trans in the flood. We are going to try and flush the fluid. Can I use my Mircon V fluid that I drained from my Superduty to use for the flush in his Jeep transmission? My fluid is in ok condition and will mostly be used for flushing. Thanks!
Old Apr 28, 2013 | 01:53 PM
h2guy's Avatar
h2guy
I'd do it but only after straining it through something to remove any particulates, before running it through the Jeeps tranny.
Old Apr 28, 2013 | 02:01 PM
Crewcab Turbo
I'm not too worked about particulate I have an external filter on my truck. The fluid in the jeep looks and smells horrible. I'm more worried about fluid incompatibility.
Old Apr 28, 2013 | 03:30 PM
Deluxe06's Avatar
Deluxe06
4000 rounds a min
What type of trany fluid does the jeeps manual say to use?
Old Apr 28, 2013 | 07:59 PM
Mark Kovalsky's Avatar
Mark Kovalsky
Frmr Ford Trans Engr
Yes, they are incompatible. Bad things could happen. I doubt that anyone has tested this to see what will happen.
On the other hand, nearly 100% of transmissions that get water in them from flooding are destroyed. The glue that holds the friction material to the clutch plates and band straps is water based. When that much water gets in the trans the glue dissolves and all the friction falls off.
MANMAN
Jan 17, 2010 05:23 PM
04F-250mark
May 5, 2009 08:51 AM
rebelyell618
Oil & Lubrication
Jul 10, 2008 02:57 PM
matis
1983 - 2012 Ranger & B-Series
May 1, 2005 11:18 PM
ford390gashog
Oil & Lubrication
Jul 5, 2004 09:15 PM
