6.0 UGH
Old Apr 27, 2013 | 02:56 PM
rickkk's Avatar
rickkk
6.0 UGH
Hi all I'm a bit I'll at the moment, Got an 04 6.0 late build,had a FICM issue back in Oct.2012 Blade helped me pin point it to my FICM,called Ed..ordered one from him, replaced old one..fixed it! Until now,same symptoms except my scan g 2 is reading FMP 46.5--47.0 FVP =13.0 FLP= 13.0 VLT= 13.3. Now why would i be having same symptoms?? Called Ed he seems to thing it's my oil cooler,said to downshift to force it, tried it ..no change. Symptoms are coughing while trying to accelerate up hill with a weird pop pop pop when letting off the pedal. No smoke, no problem cranking/starting. Has a low rumble when sitting. New Batts. It happened once after driving 1 hr trip. Cranked it in the am still acting up,drove 3 mins this am cleared up, good all the way home. UGH Any Ideas??? Thank you All in advance. Rick
Old Apr 27, 2013 | 05:57 PM
BLADE35's Avatar
BLADE35
Post these
ICP
ICPV
IPR%
BARO
MAP
EBP
ANY DTC
Is it overBoosting???
Old Apr 28, 2013 | 02:16 PM
rickkk's Avatar
rickkk
6.0 again / Blade
Here ya go Benny, and thank you sir. While checking these, the engine was going between running correct and not correct,so not sure #'s are of which way.
KOEO Low I High I
Icp 0-1 585 1516
ICV 0.23 .75 1.71
IPR 22.71 23.1 49.4
BAR 14.3 14.3 14.3
MAP 14.2 14.4 26.9
EBP 5.8 5.8 5.8
No DTC's how do I tell if over boosting? When it's acting up going up incline's it cough's/ cutting out until i let off the pedal.
Old Apr 28, 2013 | 02:29 PM
Bullitt390's Avatar
Bullitt390
Certified Thread Hijacker
Originally Posted by rickkk
EBP 5.8 5.8 5.8
Well, there's your problem. Clogged or bad EBP sensor.
Josh
Old Apr 28, 2013 | 05:50 PM
rickkk's Avatar
rickkk
Thanks Josh, took it out & cleaned with carb cleaner, ran a couple pipe cleaners thru. put it back together and the #'s have gone up while setting at my shop, have a trip planned for the am ...we will see. Thanks Rick.
Old Apr 28, 2013 | 10:01 PM
04badford's Avatar
04badford
If this helps I'm on a EGR kick this week lol pull and clean the valve with carb cleaner also MAP connection to Intake .
bustedassranch
Jun 15, 2014 01:07 PM
thty0201
Oct 14, 2009 09:56 PM
grinekb
Jan 19, 2009 02:56 PM
04excursion_psd
Aug 8, 2005 01:38 PM
