I need a new PCM. The number on mine is E8TF-12A650-Y2B. What am I looking for when trying to find one that will work? I see some eBay listing that look like they are only listing the first and last part of the part number; for example E8TF-Y2B. Is that all I'd have to match up? My truck is an 89 4.9l I6 4x4 MT. Thanks in advance for the help.
Also since I just went thru this last weekend, you want to be sure that the 3-letter-1-digit code is the same. Mine was JOY0 (just as a reference) you'll find it in the upper right corner of the sticker on the PCM. The site I used was autocomputerexchange.net. Check em out
Does anyone know what the difference between a E8TF-Z2B and a Y2B is?? I found one that is a Z2B but mine is a Y2B, it has a big 8TE instead on 8TL like mine on it though. Also, I found another PCM that was supposedly pulled from exact same truck as mine, 89, MT, 4.9L, 4x4, but I contacted the seller on eBay and he said its not compatible because my part number is different :-/...confused.
Does anyone have any experience with remanufactured PCMs? I can get this one http://shop.advanceautoparts.com/web...one_19700541-p
For 80$ plus tax after coupon. The prices I'm seeing on eBay are around 55$ and up. But I'm not sure of their compatibility with my truck.
