Borg Warner T9 shifter adjustment
Old 04-25-2013, 03:25 PM
Cameronsgobuggy's Avatar
Cameronsgobuggy
Cameronsgobuggy is offline
I've got a Borg Warner T9 that's having some trouble with shifting. In the middle of shifting gears the gear shift lever just goes limp and appears to have no contact with the internal parts (Rails, forks etc.). You have to sit for several minutes and "work" the shift lever around before you can finally get it to engage. I've looked for a repair manual or adjustment procedures but have come up empty. Does anyone know the procedures or where I can a rebuild book?
Thanks!
Old 04-25-2013, 11:52 PM
85e150's Avatar
85e150
85e150 is online now
Received 1,682 Likes on 1,375 Posts
Last edited by 85e150; 04-27-2013 at 09:54 PM. Reason: see post 3, wrong info posted.
Old 04-26-2013, 08:51 PM
Cameronsgobuggy
Thanks for the info. I'll take a look tomorrow. I have a T9 not a T19 so I don't know how similar they are. It's worth a try!
Thanks.
Old 04-27-2013, 10:00 PM
85e150's Avatar
85e150
Like from a Capri or XR4Ti?
Image View - <span< a=""> class=fileInfo>Ford Type 9 cross section diagram&credit_to=&credit_to_www=</span<>
Ford Type 9 5 speed gearbox overview
Diagram is the best I can do.
UK parts & info sources:
Ford Type 9 gearbox - Parts by Gearbox (All) - Parts by Fitment Type
Ford Type 9 gearbox information and Parts - Type 9 Home
Most everything I find goes back to the UK.
One suggestion in the first link is to replace with a T5--probably another can of worms, or not.....
Prandyseth
Bronco II
02-24-2012 05:57 PM
NDL
02-13-2007 07:45 PM
nibog
06-28-2006 10:19 AM
Northal
1983 - 2012 Ranger & B-Series
06-12-2006 12:11 PM
Quick Reply: Borg Warner T9 shifter adjustment
