M5OD-R2 2wd extension housing - need one
I have a '97 F150 with a 4.2 and a 5-speed in it - someone swapped the trans at some point and put one from a '99 and later model truck in it. Its the same transmission except the tailshaft housing is different because of the different type of speed sensor they started using in '99. I need one from a pre-'99 model M5OD. I need the housing with the speedo drive/sensor in it and I need the speedo drive gear off of the tailshaft. This is for a 2wd application.
I am hoping someone can help me here.
Note: This housing has to be from an R2, not an R1 M5OD. They are different. The R2s have 9 bolt holes, the R1s only have 8. They are very similar in appearance, however the bolt hole count will distinguish the two.
madmacs
43
01-19-2018 03:55 PM
