I have a 99 expedition 5.4 and im getting a ticking sound from the pass side recently did a timesert to num 3 cyl and changed the plugs so I know there good what else could it be it only ticks under load not at idle recentley did oil change so thats good too trucks got 145000mile on it
Twenty bucks says the retaining nut that holds the EGR tube onto the driver's side manifold has rusted off. Take a flashlight and look carefully. You'll probably see a gap between the nipple on the manifold and the base of the tube where the nut used to be. It's not an easy fix. The correct way is to buy a complete new EGR tube and pray that the threads on the manifold are still good enough for the new tube/nut. We welded the tube to the manifold on mine, and so far so good almost 10 or 12 months later. That clicking drove me insane before I fixed it.
