I just removed my exhaust manifold and need to find a new nut that holds the egr tube to the ex. manifold on the drivers side of my '97 f-150 4.6l. I've tried the dealer and I don't want to replace the whole tube which is fine, any help would be appreciated.
I planned on cutting the tube, placing the new nut on and sleeving the two pieces with a larger diameter tube...however I'm just going to wrap muffler patch over what's left of the nut and clamp it together...or j-b weld it
ya, the whole idea of shortening the tube by cutting it just doesn't sound good. jb weld works wonders, and you can but some of the exhaust tape over that.
I just had to deal with this on my Mustang during a head swap. I broke the tube off where it meets the header. What I did was get some 1/2" or 5/8" flexible copper and put the old nuts back on and flared it. I had to use some Copper RTV to seal everything up perfectly, but it worked quite well. You might be able to find a replacement nut at the hardware store and then get some copper pipe and a flare tool.
Hmm, if is that big you might have some problems. I believe you can get flexible copper in that size. Then I would get something bullet shaped that is large enough and heat the copper and hammer a flare into it. You'll need to use the RTV or something to seal it up though. At that point it might be worth looking into buying a new tube though.
I'll remember that web site for next time. I threaded what was left of the nut back on & J B welded it with a ss hose clamp over it. Thanks for all your help with the exhaust manifold removal , I did weld a nut on the stud and they all came out easily...wish I knew that trick years ago!
