My Lawn Ornament Gift - but has blown head gasket.
Ok so my friends dad gave me his old 1982 ford f250 with a 400 (so we think). But pulling the plug on the oil I quickly realized how nasty that stuff. Like thick chocolate milk mixed with ranch. It was so nasty i almost didnt want it in my oil pan cause i dont think auto zone will recycle it. All I need to do is run this truck enough to take it down to my house maybe 400 yds.
This truck has sat under a tree anywhere from 6-12 months AFTER blowing the head gasket. Looks very corroded around the hose to the theromstat.
I've flushed the milkshake oil as good as I could and filled it with new oil (think I should bother with the filter right now?) hopefully after a night of charging the battery it turns over.
MY QUESTION: what all should i replace that would be affected by a blown head gasket
the filter is probably full of that milkshake junk, which is not known for being a suitable lubricant. throw a cheapo filter on there if you do have to drive it that little bit.
if you fill the coolant, it'll just pour into the oil and make more of that milkshake junk. for going 400 yards, i would suggest taking the belt off the water pump, don't fill the coolant, just fire it up and run. it won't heat up enough in that time to do any more damage than has already been done.
if pulling it with another truck is possible, that would be better than running it.
you should plan to send the heads into the machine shop to have them resurfaced and maybe have the valves ground at the same time. closely inspect the block for any kind of pitting or gouging between the cylinders and water jackets. this pic https://www.dropbox.com/s/rjbk9nvfck...2014.38.15.jpg shows the block surface on my diesel around where it blew, if you have any damage like that, you'll need to have the block resurfaced as well. that requires a full teardown, at which point you may as well freshen up the bottom end with new rings and bearings, oil pump, and whatever else you see fit to get into.
ktm747
05-25-2012 09:36 PM
Skrilla
07-12-2011 10:13 PM
whodat54321
03-09-2006 03:51 PM
