Modular V10 (6.8l)
3V Ford V-10 issues -- HELP!
Old Apr 24, 2013 | 10:14 AM
KowboyKyle's Avatar
KowboyKyle
I'm very much at a huge loss cause I thought I had it diagnosed 100% yesterday and I was wrong.
Monday morning driving home from work, low fuel light on, planning to get gas. Truck misses & dies at highway speed. Guess it ran out of guys, no CEL. Coast into a Chevron, put in 14 gallons. No start. Pump the DBW throttle, finally idles rough, and wont idle below 1,200rpm, still no CEL. Limp it home. No start at all. No CEL. Replace the Fuel Pump Driver Module -- super common failure on 3Vs or any Ford with a returnless fuel system -- the Dorman part # crossed to over 500+ FoMoCo vehicles. Starts, idles fine, for 20 seconds, dies. No CEL. Finally figure out that rapid 0% - 100% throttle snaps will bring the engine up in RPM. Won't run below 1,800 now. Get it to work, and it throws a CEL, FINALLY. Limp it from the gym to the office, 2 miles. Won't run below 2,500 now. Let it sit overnight while I'm at work. Fellow in a different office has a code reader and pulls off these -- P2106, P016B, P2195, P2197. Limp mode, and both banks lean. 2,750-3,700rpm it drives but is very underpowered. 3700+ it pulls like a train. Under 2700 and it starts to fall on it's face FAST, dies.
Needless to say, it was a very interesting 14 mile drive home since mine has the ZF-6.
Old Apr 24, 2013 | 10:30 AM
Ridenred333's Avatar
Ridenred333
I am wondering if you didnt such dirt into the filter or one of your injectors. I dont know what those codes mean at the moment however I am sure someone will reply soon.
Old Apr 24, 2013 | 12:41 PM
Mmaxed's Avatar
Mmaxed
No clue on the codes either, but if it started this with the fuel fill, the I would look at bad fuel. Could also be that running it empty you stirred up crap that had been sitting in the bottom of the tank. Like Ridenred, I'd start with a fuel filter.
billionj
Modular V10 (6.8l)
27
Jun 14, 2020 11:08 AM
Grower67
May 12, 2018 05:39 AM
Brandon1153
May 7, 2015 06:41 AM
howler4x4
Modular V10 (6.8l)
Dec 8, 2010 08:30 AM
StealthWyvern
34
Mar 8, 2009 10:24 AM
