fan?
Old Jun 5, 2003 | 06:20 PM
johntucker05's Avatar
johntucker05
Post fan?
I have a 1995 F-150 Super Cab and it makes a very annoying noise. While driving down the road, it makes a whining sound, and at first i believed it was coming from the alternator, but i replaced the alternator, i also know it is not the drive train. Could it be the fan. Please Help!
Old Jun 5, 2003 | 11:06 PM
Ultramagdan's Avatar
Ultramagdan
fan?
Hello johntucker05 and Welcome to FTE!
I doubt it is the fan. If it was the fan you should be able to make the noise by revving the engine in neutral and hearing it.
Sounds to me like you have wheel bearing starting to go or worse a rear end that has run out of oil. Does it do it only at your normal cruising speed?
Old Jun 6, 2003 | 06:23 AM
johntucker05
fan?
it only makes the noise once I start go faster than 30 mph. i don't think it is a wheel barring because it doesn't make the noise 100% of the time. Sometimes, i can turn the A/C off and it won't make the noise, and sometimes it never stops.
Old Jun 6, 2003 | 09:46 AM
johntucker05
Arrow fan?
It did not make the noise as bad as it did yesterday. It has been coming and going all day.
Old Jun 6, 2003 | 10:12 AM
johntucker05
Post fan?
What do i have to do if the rear end has run out of oil? How much will it cost to get fixed, or can I fix it?
Old Jun 6, 2003 | 05:34 PM
Ultramagdan
fan?
If the rear end ran out of oil you probably have oil stains either around the rear differential or on your rear tires.
Since it comes and goes I doubt that it is the rear end.
Old Jun 6, 2003 | 05:52 PM
alanscott's Avatar
alanscott
fan?
What is the ambient temp while all of this is going on? It could be the clutch fan engaging and the noise your hearing is the fan.
Old Jun 6, 2003 | 06:11 PM
Bob Ayers's Avatar
Bob Ayers
fan?
Maybe the fan clutch bearing when the fan is disengaged..
Old Jun 9, 2003 | 11:47 PM
johntucker05
fan?
the engine temp is normal, and today i read that it can cause me to get bad gas milage, which i do. is this true as well?
foofees
15
Jul 7, 2017 03:19 PM
ltmadsen
1983 - 2012 Ranger & B-Series
Apr 24, 2017 12:06 PM
shore
1997 - 2003 F150
Apr 17, 2016 12:23 AM
Zazoos
21
Sep 27, 2015 04:41 PM
tims01
Aug 3, 2015 07:07 AM
