1971 F250 Highboy with Champion 4 row radiator and dual fans. Have a relay that kicks each fan on at 165 or one fan when AC head pressure is detected.
Both fans start out strong, but one gradually gets slower to the point you cannot feel it drawing any air through, while the other one is still blowing strong. This happens after the engine is completely warmed up. Moved the ground wire, just to make sure I didn't have a bad ground issue. Tomorrow I will get my volt meter in line to see if there is a drop when warmed up.
Relays are wired to the back of the alternator to maximize voltage and grounded to a bare spot on the frame.
Alternator is charging and the battery is full. All connections are clean and paint free.
You need to hook up a multimeter at the fans and observe the voltage, this will tell you wether its a fan issue or power supply issue. Once you know that then we can narrow down the issue easier.
something else to try would be to swap which fan comes off which relay. If the other fan slows then you know it's not in the fan and is either voltage or wiring/relay related.
Zazoos, you said that you grounded to the frame.
Try this: When the fan slows at temperature, run a wire directly from the negative battery to the ground wire on the slowing fan. I could be wrong but my hunch is worth a try.
The proper grounding point for this high current stuff is the battery terminal.
Let us know what you find.
If you have a voltage meter put on the battery then start engine.
And monitor your battery output volts before and then when fans come on an see what your charging rate voltage is, then turn on your head lights. If the voltage drops under 13 volts then I'd say do the 3g upgrade.
orich
Thanks for the help. I was suspecting the fan had a weak motor, so I replaced the fan. The reason for this thought is because it was showing 14 volts at the fan that would not blow hard and I even switched harness from the good fan to the bad and it still would not blow hard.
New Fan installed and exact same problem. Truck warms up and the driver side fan barely draws air through the radiator. Switched wires with passenger side fan that is blowing hard and the driver side continues to be weak.
I doubt I have gotten two bad fans.
Yes, my alternator is 60 amps, but you would think that when I switch the fan wiring harness the problem would switch to the other fan.
Also after switching the harness from the passenger fan to the driver fan I had to give the driver fan a push to get it spinning. Keep in mind the opposite wiring was spinning the passenger fan without any issue.
I am looking into the 3g upgrade now, but I am confounded about the harness switch not switching the problem to the other fan.
Are you using the fans and wiring kit that came with your Champion Rad? If so, are you running your main power feed through the circuit breaker that came with the kit? I just finished getting mine all hooked up. Both fans would start and run for 4-5 seconds, then both would start slowing down. If I tried running one fan at a time, no problem. I put my volt meter across the terminals of the circuit breaker, and you could watch the voltage jumps/ drops while the circuit breaker quickly kicked off/on. I replaced the 30amp circuit breaker with a 30amp fuse and now both fans run no problem. I guess I got a defective circuit breaker with my kit.
Ah. In that case it sounds to me like there is voltage there but not enough amperage. As I recall amperage is the current flowing and voltage is what pushes the current.
1. What happens if you run 12v directly to the driver fan?
2. Is there ANY chance the driver fan motor is binding in some manner?
With regards to #1, move the driver fan ground to the same ground as on the passenger fan and test. I can't help but think you have a bad ground on the driver fan. Double check/replace the ground wire ring terminal to make sure it has a good connection.
I ran power and ground to both fans direct from the battery with separate wires and warmed the truck up. The driver side fan started off strong but after 10 minutes of idling it had slowed way down while the passenger was still going strong. I even unhooked the passenger fan in order to give all the available amperage to the drivers fan, but no change. I'm assuming I have just gotten two bad fans in a row. Maybe a bad batch from the vendor.
Thanks for the help. I will let you know if another new fan helps.
I guess that is possible. Just not likely. I mean the odds of that happening would seam rather high. Most companies test their products before the package/ship them- I hope.
