NOT CHARGING
Old Apr 23, 2013 | 11:13 AM
team01's Avatar
team01
NOT CHARGING
I HAVE A 1999 F350 SUPERDUTY 7.3 HERE IS MY PROBLEM I REPLACED THE INJECTOR O-RINGS A COUPLE DAYS AGO. HAD ALL THE WIRES REMOVED TO ONE SIDE. GO THE TRUCK RUNNING BUT IT DOES NOT CHARGE. GOT A NEW ALT. STILL SAME THING. I NOTICED ON THE HOT SIDE ON THE ALT. THERE IS NO POWER COULD I HAVE HOOKED UP THE WIRES BACKWARDS ON THE SOLINOD ON THE FENDER ON THE PASSAGERS SIDE. WHERE CAN I GET A WIRE DIAGRAM FOR THIS TRUCK ON THE CHARGING SYSTEM. PLEASE HELP IF YOU CAN
Old Apr 23, 2013 | 01:16 PM
tommyl's Avatar
tommyl
Just had a similiar issue with my truck last week, not charging. I found a wiring harness (just under the passenger side strater solenoid). This harness is for a #2 Alternator. There was a plug in the end of harness with a loop wire corroded and broke. I was able to twist what was left of this wire back together, no problem since.
ttrapasso17
May 25, 2017 05:50 PM
blick
Nov 10, 2014 01:50 PM
jaspirr
Aug 11, 2010 10:30 PM
1979_Explorer
1978 - 1996 Big Bronco
May 12, 2010 03:38 AM
jonny bravo
Jan 27, 2006 09:57 PM
