Sponsored by: Real Truck
My rear axle code is missing
Old Apr 23, 2013 | 10:26 AM
BigBlueOx's Avatar
BigBlueOx
I'm trying to find to rear axle ratio on my 2001 F-350 dually and the axle code seems to be missing. Anyone else run into this?
Old Apr 23, 2013 | 11:36 AM
SuperDutyScaler's Avatar
SuperDutyScaler
there are tags on the front and rear diff that have the axle ratio stamped into them. I TRIED TO GOOGLE YOU VIN BUT IT COMES UP NOT FOUND FOR SOME REASON
Old Apr 23, 2013 | 11:37 AM
SuperDutyScaler
my bad hit the Cap Lock button
Old Apr 23, 2013 | 12:16 PM
r2millers's Avatar
r2millers
I bet the vin# didn't help your search as it doesn't give you that info.
Also, the axle ratio ISN'T printed on the axle tag, just the code #.
Here's a previous link that might help.
https://www.ford-trucks.com/forums/4...ification.html
Old Apr 23, 2013 | 05:00 PM
redford's Avatar
redford
FTE Leadership Emeritus
Your VIN decoded:
1FD-Ford Motor Company, USA, incomplete vehicle
W-10,001-14,000 pounds GVWR with driver and front passenger air bags
W36-F-350, Crew Cab (Chassis Cab), 4x2, dual rear wheels
S — 6.8L, SOHC, EFI, V10, Gas (pre 08)
8- government assigned, computer-generated check digit
1- model year code (2001)
E -Kentucky Truck Plant
C16388-alphanumeric code for the vehicle build sequence
Old Apr 23, 2013 | 07:26 PM
SuperDutyScaler
i dont know about your truck, but my ford, my dads ford,my brothers ford, both our ford work vans, both my buddies trucks, and ever other Ford ive ever worked on has the ratio stamped into the metal tag on the diff cover bolts
Old Apr 24, 2013 | 11:23 AM
BigBlueOx's Avatar
BigBlueOx
Yeah. The tag is missing from being rusted off so I guess I'll have to do it the old fashioned way.
What are the dually gear ratios? Usually I spin the drive shaft and count about how many times it goes around and chalk it up to the nearest gear ratio.
Say the drive shaft goes around what looks like 3 and 3/4 times then ill say its a 3.73.
But I don't even know what they offered for ratios. That link is for SRW diffs. Did the DRW trucks come with the same ratios as the SRW trucks?
Thanks for your input guys.
Old Apr 24, 2013 | 03:09 PM
r2millers's Avatar
r2millers
SDS,
I stand to be corrected. After additional research, you are correct. My mistake. I looked under my truck and see it does show a 3L73 (373 locking) on the tag. It also shows it's a 10.5" ring gear and manuf on June 19, 2006.
My door tag only shows 3L but that's the axle code only on the door sticker.
My apologizes.
Old Apr 24, 2013 | 08:28 PM
SuperDutyScaler
i wasnt trying to be a d$$k or anything, just saying all that info is on the tag.
to the OP why not just call a local dealer tell them your vin and they can tell you what you have? And since your truck is a V10 dually it could have 3.73, 4.10 or 4.30 gears from the factory
Old Apr 24, 2013 | 09:47 PM
Tom's Avatar
Tom
No need to call the dealer, see below. I went through this with my Excursion which is also lacking an axle code.
fordetis.com - fordetis Resources and Information.
I find it interesting that my Excursion has a steeper axle ratio than a DRW F350. The OP has 3.73s.
Old Apr 24, 2013 | 09:59 PM
redford's Avatar
redford
Running your VIN on FordEtis home page I get this:
Primary Features
Build Date: 05.02.2001
Vehicle Line: F250/350/450/550 Super Duty
Body Style: Double Cab (3/4 Door)
Series: 350 Series
Engine: 6.8L SOHC EFI NA V10 Gas
Transmission: E4OD(4R100)
Drive: LHD RWD
Axle Ratio: 3.73
Emission: With 49 State Emission Requirements
Air Conditioning:
Paint: True Blue
Old Apr 24, 2013 | 10:02 PM
redford's Avatar
redford
Also:
Minor Features
Dark Denim Blue
Blocker Beam-Underbody Front End
Less Tailgate Lock
Less Second Unit Body
Less load Box Edge Protectors
176"/4470MM Wheelbase
(-)"XL"
(-) Version Packages
Less Special Purpose Vehicle
Less Fleet Related Items
Kentucky Truck Plant Build
U.S. Sales
Less Special Equipment Package
11,200 LB. GVW
Less Appearance Group
Less Cold Weather Group
Less Exterior Appearance Pack
Less Power Equipment Group
Less Ambient Temp/Speed Pack
With On-Board Diagnostic System
Kentucky Truck Plant Build Only
With English Language Label
Owner Hand Book Pack
With 4 Ton Hydraulic Jack
Less Warning Display
Less Fire Extinguisher
Less Tool Kit
With Manual Front Windows
With Manual Rear Windows
With Tinted Glass
With Sliding Rear Window
Less Overhead Console
Less Floor Mounted Console
Fixed Foot Pedals
Floor Cover - Vinyl Ins - Complete
Less I/P Insert
Sunvisor Less Mirror - Drivers
Sunvisor Less Mirror - Passenger
With Level 1 Door Trim Panel
With Sound Insulation Pack Level 1
Less Exterior Sun Visor
With Grey Grille
Less Lower Body Moulding
Less Rear Window Protector
Less Side Auxiliary Step
With Dipping Rear View Mirror
Dual Sail Telesc TT Mirror-Manual
Less Temp Control Driver Seat
Less Temp Control Passengers Seat
With Seat Belt Warning Light
With 2nd Row Bench Seat - 3 Passngr
With Driver 2 Way Mnl. Seat Adjust
Less Trailer Towing
Less Trailer Towing Attachments
With Front Towing Hook
Exterior Door Handle - Black
With Manual Door Locking
Less Door Entry Remote Control Unit
Less Body Tu-Tone Paint
Less Bodyside Accent Stripe
Front Bumper Steel - Painted - Std
Less Rear Bumper
With Front Licence Plate Bracket
With Inertia Front Seat Belt
With Driver Air Bag
With Passenger Air Bag
Adjustable'D'Ring-Drivers Seat Belt
Less Passenger Air Bag Deactivation
Less Tyre Carrier
With Steel Spare Wheel
With Double Rear Wheels
6.0 X 16" Steel Road Wheel
LT235/85R-16E BSW A-T Tyres
With Conventional Spare Tyre
Less Wheel Covers
Less Hub Covers
Less Immersion Heater
Less Attitude/Ride Height Pack
With Heavy Duty Front Suspension
With Front Stabilizer Bar
With Heavy Duty Rear Springs
With Rear Stablizer Bar
3.73
Less Rear Axle Limited Slip Diff
With Dana Axle
With Twin I Beam Front Axle
With Catalyst
With 4 Wheel Disc-Brake
4 Wheel Anti-Lock Braking System
With Standard Transmissn Oil Cooler
Less Transmission Power Take Off
Less Transfer Case
Less Skid Plates
With Aft-Of-Axle Fuel Tank
Less Auxiliary Fuel Tank
With Non Locking Fuel Cap
For Unleaded Fuel
Less Gaseous Prep Pack
Less Diesel Fuel Content
With Steering Damper
With Fixed Steering Column
Basic Type Steering Wheel
Less Speed Control
With MPH/KMH Speedometer
Less Reverse Proximity Sensor
Less Engine Immobiliser
Heavy Duty Battery
Standard Duty Alternator
Electronic AM/FM/Stereo With Clock
Less Radio Pre-Equipment Pack
With NAAO Radio Frequency
With Daytime Running Lamps
With Single Headlamp
Less Front Fog Lamps
Roof Marker/Clearance Lights-Conv
Less Engine Compartment Light
With Dome Maplight
Less Glove Box Illumination
Less Load Compartment Lamp
Tail lamps - Level 1
Less High Mounted Stop Lamp
True Blue
F81A 5310 TA Left Front Coil Spring
F81A 5310 TA Right Front Coil
Less B&A Control Codes Issue 030388
Less LPO 50S Emiss Calib Label
(+)"USA"
(-)"CDN"
(-)"AUS"
(-)"RA"
(-)"GU"
(-)"BRN"
(-)"VN"
Old Apr 25, 2013 | 05:39 AM
BigBlueOx's Avatar
BigBlueOx
Thanks a ton guys. That just what I was looking for.
packnrat
Oct 3, 2009 10:31 PM
MikeSDK
Feb 14, 2006 02:09 PM
gingerbreadmaniac
Apr 26, 2005 09:17 PM
fordtrucksforever
1978 - 1996 Big Bronco
Aug 14, 2002 08:42 PM
74F250
May 4, 2002 06:58 PM
