Front Axle Ident
Apr 26, 2005 | 02:58 AM
Front Axle Ident
D7TAZC6100104R
the vin # is F26HCY83980
-gbm-
Apr 26, 2005 | 11:39 AM
What is the code for the rear axle ?
Apr 26, 2005 | 12:48 PM
forgot to check, its a truck im looking at buying.
cant tell from the tag on the diff?
-gbm-
Apr 26, 2005 | 01:16 PM
Not with the info you posted.
I need the rear code to help determine the front code.
The front axle ratio has to closely match the rear axle ratio.
ie: Rear 4.11:1 = Front ratio 4.10:1
These ratios were only available in certain diff make-up.
ie: 9".... dana 60...dana 70
btw, you don't need to use the quote in a 2 way conversation
I know who says what
Apr 26, 2005 | 07:40 PM
Quote:
body du4
trans A
axel 24j
Gawr front 3500
rear 5300
-gbm-
Apr 26, 2005 | 08:36 PM
Axle code 24 is a Dana 60, 5300 lb, 4.10:1 ratio with an open differential. J indicates power steering.
The 'A' transmission indicates a New Process, 4 spd manual transmission.
Apr 26, 2005 | 08:46 PM
The front is probably a Dana 40 with a 4.11:1 Ratio
Apr 26, 2005 | 08:47 PM
edited: posts made while typing
-gbm-
Apr 26, 2005 | 08:52 PM
ok i never even heard of a dana 40 but ok ill trust you, im really shooked we cant narrow it down instantly with the codes and tag numbers iv found
So im assuming its the lighter duty front end but will it stand up to me hunting with it???
-gbm-
Apr 26, 2005 | 09:07 PM
didnt they use gear ratios up front just a tad bit higher Ie. faster so the front end pulls instead of got pushed??? so would there be a 409:1 ratio in the front???
-gbm-
Apr 26, 2005 | 09:09 PM
Yes, that is possible.
Probelm is ,I can't find an application for that axle in the book.... for that year.
Apr 26, 2005 | 09:12 PM
ok well ill get all the info you guys need tommorow, im probly gonna buy the truck.
either way is the dana 40 or 44 strong enough for just your average outdoorsman who doesnt really plan on running huge tires or driving it hard???
-gbm-
Apr 26, 2005 | 09:17 PM
D7TA-Z = Year /design & application
C6100104R = Plant casting number for plant employees.
Private e-mail sent.
