6v to 12volt?
The answer is....it depends.
If you want a 12v positive ground alternator and battery, you can install that with some fabrication for alternator brackets. You can use the 6v starter & it will crank twice as fast. You will probably also want to convert the ignition system and lighting to 12 v.
There are 12v to 6v reducers from places like Speedway Motors that you can use if you want to keep all of the original gauges. Look here: Voltage Reducer from Speedway Motors, America's Oldest Speed Shop
Another path is to completely re-wire the whole truck with new harness. There are several available for around $200, but you do have to buy an alternator, battery, all of the light bulbs, and you'll have to do something about your gauges.
Keep in mind that your existing system is a 6v positive ground, so if you keep part of it and discard part of it you'll have to pay attention to polarity. A good approach for an alternator is to use a GM 1 wire unit. Summit Racing has a few of their own brand that are repackaged GM units and are priced right.
Speedway does have a 6v to 12v conversion book that is probably a good reference.
You should post some pics of your truck!
Dan
Quote:
Originally Posted by 76f350spercamprspeal
Welcome to FTE, Best Damn Forum EVER!
Here's How to Post Pictures:
1. Login to FTE.
2.Click User CP (In the Top Left Hand Corner)
3.(On the Left, There will be a list, The 5th Option Down, will say "Pictures & Albums) Click That.
4.Then, Click Add Album, Enter a title, and description, if ya want to.
5. Click Upload Pictures, Then click Browse, Locate the Files of your truck. (You can add 3 files at a time)
5. Click Upload.
6. Add a description to the individual pictures, then click save.
7. Add more files if ya want.
8. Click The Picture you want to post, it will give you two codes at the bottom, Right Click The Second one (It say's BB Code, Then Say's [IMG]http:blahblahblah...[/IMG])
Then, Once that is highlighted, Right Click, Then Copy, Then Paste it into your post.
You can add up to 30 Images in one FTE Post.
If, Ya need any help, Don't hesitate to ask.
Quote:
Originally Posted by old_dan
You can also go to the "Garage" tab and start an album right here on FTE. After you post pictures to an album, we can look in your album, but you'll also be able to "insert a picture" by pasting in a link to the picture in your album.
It seems awkward, but whenever you "insert a picture" to one of these threads, the forum is looking for the picture somewhere on the web (which is always available) rather than from somewhere on your hard drive (which isn't always available).
Quote:
Originally Posted By Jolly Roger Joe
Welcome to FTE!
Go to Image hosting, free photo sharing & video sharing at Photobucket and sign up for a free account. Then create an album for your truck. Upload any pics you want to post on FTE to that album. Have this album open on your computer when you want to post pics on FTE.
While you're making a post on FTE, select the pic you want to post from your Photobucket album. When the large version of the pic is open, right mouse click on it and select "View Image Info". The image info will be highlighted and will look something like this:
The best photos and videos | Photobucket
Copy that highlighted info (right click / copy).
When you have the spot in your post where you want the pic to be placed, select the "Insert Image" icon at the top of the post (looks like a mountain) and paste (right click / paste) the image info you copied in the highlighted box (just shows "http://" when it opens).
Your pic will be placed in the post.
Hope that helps.
Here's a tutorial Bob put together: https://www.ford-trucks.com/forums/67...-pictures.html
At the time they had a $100 rebate, so it was around $200.
Others will weight in, but EZ wiring is a good choice: Wiring Harness
Here's a link for Speedway's store brand: Speedway 20 Circuit Wiring Harness - Speedway Motors, America's Oldest Speed Shop
All of these include a new fuse block, modern fuses. I think they all use a GM connector for the turn signals at the steering column which is more or less the industry standard.
Dan
The stock radio was 6V only. If a lower power radio is ok with you then a 12V radio can be run with an inverter. My Dad's 40 sedan was set up this way by the previous owner. If you want a 4 speaker 300 watt stereo then you need 12V.
If your newer engine has a carburetor, points, and a 6V starter from an earlier engine will bolt on, then yes it will work fine on 6V. If you want fuel injection, electronic ignition (other than the Pertronix points replacement), and no 6V starter can be found, then you will have to convert to 12V.
What are you planning for an engine? I also advocate keeping the flathead.
