400 small block help?
Old Apr 22, 2013 | 08:59 PM
Smallblock400's Avatar
Smallblock400
Hello, im looking into buying a old ford truck, I havent found many that are worth buying except for a 1977 ford 250 camper special with a 400 small block in it, its a 2wd truck and is in Great shape for 1500$
Im really interested in this truck but i never did like the 400's low amount of horses.. So i did a bunch of research and all i could really find was a 500 hp 400 made for 7 grand.
I dont have 7 grand just kickin around, so i plan on building up the horses and torque slowly.. Buy new performance parts for her if i buy her.. But i have not seen any threads about people slowly modifying a 400? it seems the people with 400's just put 5 + grand into it right away..
So my question is, What kind of things could i do to a 400ci ford motor, that wont cost more then $1000 or so at a time?
Thanks
Old Apr 22, 2013 | 09:22 PM
Poison Oil Racing's Avatar
Poison Oil Racing
put in a good cam, timed straight up - not retarded like the factory did, and good exhaust.
Old Apr 22, 2013 | 09:34 PM
Smallblock400
any suggestions for a cam?
Old Apr 23, 2013 | 12:32 AM
privateer, eh's Avatar
privateer, eh
Scroll down the forum list until you come to the 335 forum, you'll see what others did.
POR is right and look for either a wieand or edelbrock manifold. A 600 carb goes a long way but if you want to go big power down the road get a 650 and jet it down for now. That 400 is a big block and when you shop for headers you can include the 351 C. That motor is all torque and weighs 200 lbs less than a 460.
Old Apr 23, 2013 | 12:44 AM
85e150's Avatar
85e150
1) Make sure it's a 400. Check the stroke with a wire. Hard to do on that motor, but try anyway.
2) Don't go there with BB or SB. The 400 is tall like a BB, but has the SB bore spacing along with the BB 385 series bell. "Mutt" is one name given with great affection.
2) These have low compression and a terrible cam. You can replace the cam, but if your motor is worn and has blow by or uneven compression test results (do a compression test no matter what you are going to do), you will end up doing your work all over again.
3) If you have poor results from your compression test, put some decent pistons in it along with the cam. Even with the stock manifolding and carb, you will gain massive power compared to stock.
4) Go here TMeyer, Inc. Precision Automotive Machining
You don't need heads if yours are good. You will need valve springs if you change cams, so you will put new seals it at that time as well, if your heads are otherwise sound.
5) 351C headers might bolt to the heads, but since the 351C is an inche shorter, fitment issues may follow. https://www.ford-trucks.com/forums/1...n-a-400-a.html
6) Did you go here? 335 Series- 5.8/351M, 6.6/400, 351 Cleveland - Ford Truck Enthusiasts Forums
Old Apr 23, 2013 | 08:55 PM
Blue and White's Avatar
Blue and White
I've got a '78 F250/4 wd/4.10's/31" tires with 400M. Mine's pretty low mileage (40k). Eventually, I plan upgrades, either cam/intake/carb/exhaust or maybe a full rebuild and head upgrade. I'm not in a hurry though. It is in decent shape and works pretty well dead stock. It has done OK towing 6000k+.
Meats12
Apr 8, 2014 12:28 PM
PDX_F250_78
Jun 29, 2010 12:41 PM
jdawwggin25
Oct 1, 2004 07:31 PM
clovis
16
Nov 26, 2001 10:15 PM
