Sponsored by: Real Truck
Exhaust question
Old Apr 22, 2013 | 04:36 PM
cybane's Avatar
cybane
Exhaust question
Hi guys,
I have a 2003 F-250SD V10 with stock exhaust. Is there much gain, performance or otherwise by changing from 2.5 inch to 3 or even 3.5 inch sized exhaust?
The SD is mainly used for towing a 6k pound trailer and seems to struggle. I am adding a new K/N intake kit and am considering exhaust upgrade. I will also be changing rear end ratio from 3.73 to 4.30 which will provide best towing results. So my question is, is it really worth upgrading the exhaust size or should I just change out stock muffler to Magnaflow or similar performance muffler?
Thank you
Mike
Old Apr 22, 2013 | 04:41 PM
EXv10's Avatar
EXv10
Originally Posted by cybane
Hi guys,
Thank you
Mike
I would just change the gears for towing.
Old Apr 22, 2013 | 07:18 PM
redford's Avatar
redford
FTE Leadership Emeritus
Replacing the stock Y-pipe is perhaps the best modification you can do on the 1999-2004 exhaust system, in terms of bang for the buck.
Dutch Semi
May 4, 2012 02:06 AM
System
6.7L Power Stroke Diesel
Mar 19, 2012 05:47 PM
ArmyRanger
1983 - 2012 Ranger & B-Series
Nov 5, 2004 02:20 AM
