Radiator leak
Old Apr 23, 2013 | 02:54 PM
BigBlockF350's Avatar
BigBlockF350
Originally Posted by Beechkid
FYI- Chinese mfg.....short term life, overheating, etc. almost guaranteed.
Almost everything's made in China/Japan/Korea now (even American vehicle original parts), and quality has gotten better. I helped a buddy put a Ready-Rad radiator in his 4.0 Ranger a good while ago. Still holding up fine.
Old Apr 23, 2013 | 03:23 PM
Beechkid's Avatar
Beechkid
Sorry, but Chinese mfg still holds a 15% QA standard...meaning 15% in the hands of a consumer is acceptable. With regards to Chinese built radiators, assuming you have the proper number & diameter of tubes & fins, 99% do not provide for an anode ...in an aluminum core, that induces or advances corrosion not only in the radiator but through the cooling system...1st to typically show up is shorter life of the radiator hoses.
I still purchase US made parts for 99% of everything that I work on...going back to the 70's & 80's when the mexico mfg phase was going on...same sone, different planet. That's why I highly recommend US radiator.
Old Apr 23, 2013 | 04:47 PM
Ridenred333's Avatar
Ridenred333
Originally Posted by oneowner83
It only leaks about a cup's worth in a week, so I'm not pressed to act right away. I'll probably buy new based on ur advice. I'm a one-owner with 200K, buying new is a long term investment. I may even do it myself. Can the radiator slide out while the condenser stays put? 4.0 SOHC. Thx
I am not sure I will take a look and see if it can come out without touching the condenser when I get home.
Old Apr 23, 2013 | 07:20 PM
oneowner83's Avatar
oneowner83
I'm old enough to remember when Japanese meant Crap. Twenty years later they were showing the Big 3 how to make cars. Chinese manufacturing has soared, including the Big 3 making cars and parts there. They make more Buicks in China than in the U.S. Wooow!
Old Apr 24, 2013 | 02:29 PM
Beechkid's Avatar
Beechkid
By SAE standards, 1% failure rate is unacceptable in US production standards (this is also ISO, Sigma, TQM, TPM, I could go on).....the US standard is 1% internal (not external ie customer), Chinese standard for example is 15% failure rate (internal). This does not nor should be implied to say that this should mean there should be no failure at the customer level, that is just not realistic as everyone would agree. But let's assume that a mfg's 1% failure rate in the marketplace is acceptable, by comparison this would mean every day 100,000 prescriptions would be incorrectly delivered to customers (statistics provided by FDA & Harvard).......would this be acceptable to anyone- of course not. Per both GM & Ford, if each production run of any single vehicle series was built 99% to standard (ie 1% failure rate @ market/consumer deliverable), no less than each vehicle would have on average 15 defect's (published data available). Now before anyone says it, I will- yeah, we all know of certain vehicles that everyone considered "lemons" and everyone has known more than one person who bought one of these that had at least 15 defects of more. In summary, consumer's simply do not accept 1% failure rate in any significance of large scale consumer population.
You must also remember that 100% of all the equipment used in mfg in china....belongs to china and cannot be removed or used for any other purpose. Also (as shown in published reports) currently 10% of all e-soft & hardware products from china are embedded with very sophisticated spyware....and the newest versions are imbedded in the silicone chips themselves.......
just an FYI.......
Old Apr 24, 2013 | 03:47 PM
Ridenred333
You should have no problems with taking the radiator off and not having to touch the condesor
Old Apr 24, 2013 | 06:59 PM
oneowner83's Avatar
oneowner83
Great! Thanks.
offwhitefueler
18
Dec 31, 2018 11:38 PM
mibson
1983 - 2012 Ranger & B-Series
19
Nov 15, 2009 04:58 AM
B-52
6.4L Power Stroke Diesel
Sep 22, 2008 06:42 PM
ElvishWarrior21
Jul 3, 2003 02:29 PM
