Radiator leak
Old Apr 22, 2013 | 12:30 PM
oneowner83's Avatar
oneowner83
Radiator leak
I've got some dripping of antifreeze on my 2000 Explorer.
I figured maybe I'd try a recommended "stop-leak" product.
Anybody had any luck?
Old Apr 22, 2013 | 01:32 PM
BigBlockF350's Avatar
BigBlockF350
Don't use any type of "stop leak" product. May seal the leak today, but cause other issues tomorrow. It can gunk up everything in your cooling system.
Have you found where the leak is? Check your water pump. When a water pump is getting ready to go (bearings), it'll weep a little coolant out of it.
Old Apr 22, 2013 | 02:14 PM
Beechkid's Avatar
Beechkid
I have always kept a bottle of Barr's stop leak around for "emergencies"...for a temp fix it does work and will not harm/clog anything.
Old Apr 22, 2013 | 07:36 PM
oneowner83's Avatar
oneowner83
That's what I was afraid of...two conflicting opinions.
The leak is at the bottom of the radiator, the fluid collects there.
Everything else is dry.
Old Apr 22, 2013 | 09:42 PM
shorod's Avatar
shorod
At least years ago Bar's Leak did an impressive job of sealing up most small cooling system leaks and generally doesn't plug anything. I suspect you'll find that even on the bottle it's referred to as a temporary solution. If not, it should be. And the leak will likely reappear at the most inconvenient time and place.
Also, once you are required to repair the issue correctly, the coolant will need to be properly discarded, the system flushed, and fresh coolant installed.
-Rod
Old Apr 22, 2013 | 10:48 PM
Chugalug's Avatar
Chugalug
I saw an explorer radiator for sale on the forums market place today.
I have used Bars leak before on several occasions with mixed results.
Old Apr 23, 2013 | 08:43 AM
Ridenred333's Avatar
Ridenred333
I wouldnt us any stop leak unless it was an extreme emergency then flush system as soon as you get it home I know several people who has ended up with plugged coolant ports and other issues from that stuff it a quick fix not something that should be long term. A day or so fine. Bite the bullet and get a radiator if you cant afford a new try a junk yard. How do you know for sure its the radiator? I could be from thermostat housing these are known for that problem. Or you could be leaking fluid from the weep hole indicating an issue with the water pump.
Old Apr 23, 2013 | 10:01 AM
BigBlockF350
If you remove the radiator, is the leak in a place where you can solder it to fix it? That may work. If not, I'd just replace the radiator.
Old Apr 23, 2013 | 10:09 AM
Ridenred333
If I am not mistake these are aluminum radiators. plus plastic tanks now days. I was having same issue with my F250 and shops no longer will do anything with a radiator anymore except change it out.
Old Apr 23, 2013 | 11:37 AM
Beechkid's Avatar
Beechkid
FYI- Even the plastic units are repairable & IMHO should be the 1st option...locate a good radiator repair shop, let them pressure test it, then if repairable, let them clean & rebuild it....the cost is typically less than a replacement and is every bit as good as oem. If you choose not to repair but replace, may I suggest US Radiator....
US Radiator has been around for 40+ years. The guy who presently owns it started working there 30 years ago and with the exception of 1 or 2 items, everything is built at their facility. They are also great to talk with on the phone and if you tell them exactly what you have, what are your concerns or wants, they will tell you exactly what to order. I don’t know of anyone (including the racing community) who has not been pleased with them!
Link: U.S. Radiator | The Difference Is In The Tooling
US Radiator Corporation
4423 District Boulevard
Vernon, California
323-826-0965
Old Apr 23, 2013 | 01:38 PM
Ridenred333
Vernon, California
323-826-0965
thanks for mentioning u.s radiator however where I am living right now there are no radiator shops atleast from the research I have dont. I have called around to several different mechanics and most of them have told me that the ones that were around here have gone out of business as there was not enough need. I remember when I was a kid there was a guy that my dad us to go to and that is all this guy did was rebuild radiators and starters.
Old Apr 23, 2013 | 01:48 PM
oneowner83's Avatar
oneowner83
It only leaks about a cup's worth in a week, so I'm not pressed to act right away. I'll probably buy new based on ur advice. I'm a one-owner with 200K, buying new is a long term investment. I may even do it myself. Can the radiator slide out while the condenser stays put? 4.0 SOHC. Thx
Old Apr 23, 2013 | 02:34 PM
BigBlockF350
Even if it's a small leak now, who knows when it could get worse. Try to get it fixed soon.
Buying new is probably the best option even if it's repairable.
Not completely sure, but I think you can get the radiator out without messing with the condenser.
Good luck!
Old Apr 23, 2013 | 02:38 PM
BigBlockF350
Advance sells a radiator for your Explorer for $170: Buy Ready-Rad Radiator 431384 at Advance Auto Parts
Old Apr 23, 2013 | 02:42 PM
Beechkid's Avatar
Beechkid
FYI- Chinese mfg.....short term life, overheating, etc. almost guaranteed.
