1978 - 1996 Big Bronco
No Ignition ?
Old Jun 5, 2003 | 12:23 PM
Snook's Avatar
Snook
No Ignition ?
My truck died off about a month ago, the last few symptoms where runing ruff and missing, then it never started again,I owend the Haynes and chilton books and tested everything,I also replaced the distributor with an included Ignition module,cap and rotor, coil and at last found a new computer for it, still is not cranking.
I have fuel,the rotor turns,good battery.
Why does this truck don't Start?
1987 Bronco 302 TFI-IV EEC-IV.
Old Jun 5, 2003 | 01:06 PM
steve83's Avatar
steve83
No Ignition ?
Originally posted by Snook
...tested everything...
Did you test the fuel pressure at the rail with a gauge? Did you test the ignition system according to the Haynes procedure in Ch5 Sec7? Did you pull the codes?
Old Jun 5, 2003 | 01:20 PM
Snook's Avatar
Snook
No Ignition ?
I did not pull the codes.
can I pull codes with just a voltmeter ?
Thank you
Old Jun 5, 2003 | 01:36 PM
mrwizard's Avatar
mrwizard
No Ignition ?
You don't even need a volt meter. Click on the blue link in Steve's post and you'll find the directions.
Old Jun 15, 2003 | 10:57 AM
BroncoBlasta's Avatar
BroncoBlasta
No Ignition ?
hey whats up i got the same prob with the same truck the 87 bronco with the 302(5.0) i am have the same prob it will crank over but no spark so it wont start an i have replaced the coil - distributor- cap- rotor- ecu- ign mod- plugs - wires - an i still have nothing either i was told to check the ignition switch or to see if i or(we) got a bad ground or wire an i have but they are all fine so i dunno what to do any more but hey maybe we can do some thing together about this if you wanna call just give me email at deadlyduo1922(No Email Addresses In Posts!) an i will give you my # an you can call an we can see what each other has dont to gross what we got so far
also check out my forum i got in here its called (no spark)
Old Jun 16, 2003 | 06:26 PM
Snook's Avatar
Snook
No Ignition ?
I haven't got time to mess around with it by my next step is going to be reading carefully how to pull codes and go from there,steve83 was gentle and gave to us all we need to pull codes. since the EEC-IV monitors and gives comands to so many emission components we need the codes to go straight to the problem, on of those components is probably fried and the EEC-IV is saying sorry no spark.
Now I'm going back to my six and watch racing Bye !!
Old Jun 17, 2003 | 09:21 AM
Bodyman Chuck's Avatar
Bodyman Chuck
No Ignition ?
there are two small wires on the negative post make sure they are both hooked up.one of them will keep it from starting.
Old Jun 17, 2003 | 02:00 PM
Snook's Avatar
Snook
No Ignition ?
I will look into that immediatly !!!
Are those the wires that look like have an inline fuse or somthing?
Old Jun 17, 2003 | 09:12 PM
Bodyman Chuck
No Ignition ?
yes they are single inline connections no fuse.but they do look like that
LARIAT 85
Aug 29, 2006 01:55 PM
kanuckF-150
Feb 18, 2005 02:57 PM
Lance1930
Jul 29, 2004 12:17 AM
Oscar Meier
Sep 16, 2003 10:01 PM
Duct Tape
Aug 26, 2002 11:40 PM
