Ignition Trouble
Old Feb 6, 2005 | 02:29 PM
kanuckF-150's Avatar
kanuckF-150
Angry Ignition Trouble
I am new to this repair gig so I was wondering if anyone could help me with my ignition. The TFI-IV system is not working where should I start.
Old Feb 6, 2005 | 04:49 PM
IB Tim's Avatar
IB Tim
FTE Leadership Emeritus
...Welcome to Ford Truck Enthusiasts! If you have a minute check out the Guidelines, it will help you to navigate through and understand FTE.
Stick around someone will be by shortly to answer your question.
We are pleased you have chosen the best source for Fords!
Enjoy FTE …..See you on the boards.
Old Feb 7, 2005 | 02:38 AM
92supercab's Avatar
92supercab
First check for codes, it is possible that the Ignition Module has gone bad or the pick-up coil in the Distributor. Also the easy ones: worn out cap+rotor, Bad coil, Loose wires. I had an ignition module tested at autozone once, and they were able to tell me it was bad. First I would check the codes. Hope this helps.
Old Feb 9, 2005 | 10:29 PM
fordpickupguy2001's Avatar
fordpickupguy2001
89 F-150 L6 Lights make it run bad
Ok here is the prob as I see it. I go to work in the day time and it runs fine. At night with lights, blower, wipers on it runs like crap. Kinda sounds like it runs out of gas. I have a fuel pressure tester mounted inside the cab to see if it's a pressure problem, it stays at 55-58 at all times. Also I have replaced alternator and had it tested at Ford before I put it on, it held 14.3 under a load. I Installed it in the truck and temporarly attatched voltmeter to it so I can see going down the road and it's holding 13.99 with lights on, with blower on it holds 12.94. I checked coil, cap, rotor, wires, (NEW) plugs, also gapped right. Everything is in spec. Any ideas from here on out are just guesses on my part. I also have ran codes and got 52 and 67 (PWR Steering SW, Neutral SW.) So basicaly no codes are being given.
Old Feb 18, 2005 | 06:39 AM
fordpickupguy2001
89 F-150 L6 Lights make it run bad(fixed)
Well I sure would not have guessed what it was right off the bat. I checked for a vaccum leak on the temp control and all the vaccum actuators didn't find anything. I went back under the hood while it was running with a propane bottle to look for leaks there didn't find anything. I saw a bubble of tape on the fuseable link for the alternator and decided to look deeper at it and that wire was pretty hot when I touched it so that didn't seem right so I took all the wires off the starter solinoid and I found rust on the terminals I cleaned them and put dielectric on it and low and behold problem has been fixed. So therefore it was getting volts just fine but no amps and that was the problem. I been drivin it for a week and it's runnin like new.
Old Feb 18, 2005 | 02:57 PM
92supercab's Avatar
92supercab
Glad to hear you got it fixed.
cts1954
Mar 11, 2013 03:01 PM
ahurt1973
Oct 25, 2006 02:52 PM
novadragman2005
30
Feb 16, 2005 03:20 PM
mitchw32
Jan 31, 2005 08:21 PM
Gus44
Jan 1, 2003 07:09 PM
