Howl After Replacing Up Pipes
Old Apr 19, 2013 | 07:17 PM
Ummms's Avatar
Ummms
Ok, So last weekend I replaced my up pipes on my 2000 excursion with 210K miles on it. When taking everything apart I noticed that all 4 of the bolts that hold the turbo together (the exhaust housing to the compressor housing) were either loose or completely backed out. I then replaced the bolts and snugged the turbo back together. I put everything back together, finished installing the up pipes and then I went for a test drive. My boost level on my econo tune went from 20 lbs max (before the new up pipes) to 21-22 lbs max after the up pipes, however whenever the turbo begins to spin or when I shut the truck off I can hear a howl that I never had before. As soon as my ex begins to have any boost (1+ psi) the howl disappears. If I am at highway speeds (turning 1300+ rpm) coasting then I apply the throttle there is no howl, it seems to be at very low rpm with very little throttle. I checked for play in my turbo and I did not feel any (side to side or in and out). The howl is not very loud, if I have the radio barely on I can't hear the howl.
I have checked all my boots on my IC and everything I took apart. Am I missing something or is my turbo on its way out?
Old Apr 20, 2013 | 01:11 AM
Stewart_H's Avatar
Stewart_H
Moved to the 7.3L PSD forum.
Stewart
Old Apr 20, 2013 | 06:04 AM
Tugly's Avatar
Tugly
I can think of two possibilities, without having a vid to hear it:
  1. One of your IC tubes are seated too deep into your upper boot, allowing it to vibrate against the hard-mounted spider.
  2. Your intake sucks. Many people with 6637s (and the like) get a lot of noise from a properly-working turbo.
You ain't seen nuthin' yet. Take that red tube off the cylinder above the turbo (driver side). Shove the end of the red tube onto a boot clamp bolt to prevent air from leaking through the tube. Go for a drive, but take some extra chonies with ya.
Old Apr 20, 2013 | 09:18 AM
Tailgate77478's Avatar
Tailgate77478
Originally Posted by Tugly
...but take some extra chonies with ya.
I don't mean this to be a silly question, but what in the heck are "chonies" I have no idea what you are talking about.
Old Apr 20, 2013 | 09:26 AM
Tugly's Avatar
Tugly
Slang for junk drawers, undies, whitey tighties, Fruit of the Looms, etc....
That or a squeegee.
Old Apr 20, 2013 | 11:43 AM
2000ca250's Avatar
2000ca250
Ehhh I'm betting its some frequency related vibration. I'd go back over everything and see if your new uppipes are touching the firewall anywhere, or your downpipe. If not that, then check intercooler pipes etc.
Lastly, forget the 20's for boost number. Havent experienced a permagrin until you catch 5th gear and hit 40psi of boost out of a s468 flowing right around 1350 CFM....That right there is a beautiful feeling.
Old Apr 20, 2013 | 12:19 PM
Tugly's Avatar
Tugly
I'll bet... but we mere mortals must get our thrills where we can.
Old Apr 20, 2013 | 12:20 PM
JT250's Avatar
JT250
That or a squeegee.
I believe it is actually Spanish right? Not.slang.
Old Apr 20, 2013 | 12:37 PM
Tugly's Avatar
Tugly
I've seen references to it in urban dictionaries (there's an exciting read), so I can't always keep my English from my Spanish from my Spanglish.
Pinche lengua.
addybeer
Dec 12, 2012 11:31 AM
Christof13T
21
Oct 3, 2012 09:09 AM
60RatRod
Nov 7, 2009 06:26 PM
bushman31
Jan 30, 2007 08:49 PM
Brimhall
Jul 2, 2003 11:39 PM
