Sponsored by: Real Truck
2002 SD Blower Speed Problem
Old Apr 19, 2013 | 03:19 PM
Fishin Technician's Avatar
Fishin Technician
Hello All,
Currently My AC / Heat blower motor operates but, speed 1 and 2 are the same, 3 and 4 are fine. I replaced the blower rheostat that is located on the firewall, but still no difference in fan speed.. A few years ago the blower only operated on Hi and the rheostat was the problem then.
Any ideas would be most helpfull.
Regards,
Dan
Old Apr 19, 2013 | 09:28 PM
Yahiko's Avatar
Yahiko
Melted plug?
Check it real close to see. The next place would be the dash switch.
Sean
Old Apr 20, 2013 | 08:03 PM
MeanGreen460's Avatar
MeanGreen460
I had the same problem as you stated with my 2003 I replaced the rheostat all speeds worked fine for 5 months then I was having the same problem .I have low speed and hi no in between.Id said the hell with it been driving my truck 2 yrs since with just hi and low.I had no fuses blow no lights dimming 'But if I was guessing I'd say the blower switch is bad
Old Apr 23, 2013 | 03:11 PM
Fishin Technician
Thank You all for the replies. The plug is fine ,so I will just have to assume that the blower switch is defective.
Thanks
F/T
03F250SD
Apr 26, 2015 12:42 PM
lasmacgod
2004 - 2008 F150
Nov 6, 2010 09:54 PM
Madmike33
1983 - 2012 Ranger & B-Series
Oct 11, 2006 08:56 AM
quarter
Dec 16, 2003 09:12 AM
pancake
Oct 26, 2003 10:06 PM
