Sponsored by: Real Truck
Trailer wire issue.
Old Apr 19, 2013 | 09:56 AM
Ridenred333's Avatar
Ridenred333
Trailer wire issue.
I have both the 7 prong and 4 flat wires on my truck. They worked fine for the longest time now for some reason I dont have running lights for my trailer I have brake light and turn signal lights just not running lights. I did use a volt meter to check it at the socket and nothing. The only thing I can thing of to do is start following the wire back and see if there is a spot where there is a break in the line. However before I do that is there a fuse anywhere that I should know about for the running lights. Thanks
Also the electric trailer brakes work fine and like I said all other lights work.
Old Apr 19, 2013 | 10:09 AM
meborder's Avatar
meborder
there is a fuse for the trailer running lights. It should be in the fuse box in the cab.
check your owner's manual for the fuse number.
if you don't have an owner's manual, you can download one from the ford webpage.
most likely just a fuse, don't do anything else till you check that.
Old Apr 19, 2013 | 10:18 AM
Ridenred333
Thanks for the quick reply that was the answer I was looking for. When I go home to day I will check it. It that is the problem it should be an easy fix unless it keeps blowing the fuse
JTBirkett
All Things Towing
Jun 22, 2019 01:23 PM
GeneLaw1
Dec 14, 2011 08:57 AM
John Puig
Dec 7, 2010 05:20 PM
aphotic26
Aug 26, 2010 09:42 PM
Eric H
Jul 25, 2010 07:27 PM
