Sponsored by: Kumho
Need help with rim sizes.
Old Apr 18, 2013 | 10:29 AM
sleeve21's Avatar
sleeve21
I have a 1983 ford bronco, I am trying to get new tires for it my buddys got some that i am gonna get from him. Now here is the tricky part, i need a set of 16 inch rims, maybe just some cheap steel rims not to worried about rust as long as the bead seals, that will bolt onto my bronco. Any ideas would be helpful.
Old May 6, 2013 | 07:37 PM
grantpage's Avatar
grantpage
You could try 5 lug dodge wheels they use the same 5 on 5.5 lug pattern, you may have to drill out the center of the wheel to fit over the hubs. I used a set off an early 2000 dodge on my 62 ford 4x4.
Old Jun 13, 2013 | 10:50 AM
sleeve21's Avatar
sleeve21
thanks man i had that thought in the back of my head and my buddy just wrecked his truck so im buying the rims off of that, what would be the best way to bore out the center where the hub goes?
primer85f150
Mar 25, 2010 11:19 PM
spkennyva
Feb 13, 2010 06:51 PM
jbirdsvt
Offroad & 4x4
24
Jul 27, 2005 04:49 PM
impact
Sep 18, 2002 04:24 PM
