non ford rims
Old 03-25-2010, 06:10 PM
primer85f150's Avatar
primer85f150
primer85f150 is offline
non ford rims
I am in need of new(er) rims for my 85. no 24s or anything. found some dodge rims 17in $125 for the set . will they fit ? they are 5-5.5 . work truck rims grey . just have to get center caps . hate do it but its the best deal ive found. thanks
Old 03-25-2010, 06:18 PM
fatdan460's Avatar
fatdan460
fatdan460 is offline
bolt pattern is the same, back spacing is probably different, but shouldn't be a problem.but it's kinda something you gotta try before you buy. don't wanna pick up some useless rims
Old 03-25-2010, 08:38 PM
Archion's Avatar
Archion
Archion is offline
The hole in the center of the rim on some Dodge's is a diffeerent size if memory serves me. Youll wanna check that.
Old 03-25-2010, 08:43 PM
fatdan460's Avatar
fatdan460
that's on 8 lug rims. its cause ford has a larger full float hub on rear axles. dodge fit i believe, but chevy has the small hole
Old 03-25-2010, 11:19 PM
fepowerguy8's Avatar
fepowerguy8
fepowerguy8 is offline
I concur
Ya they should bolt on. From what I've seen the Dodge has the biggest center and Chevy had the smallest. I often switch my rims around on dodges and fords.
