Sponsored by: Real Truck
ABS light on
Old Apr 18, 2013 | 05:03 AM
drey04's Avatar
drey04
ABS light on
Well... my ABS light popped on two days ago. I was pulling a 6x12 trailer filled with random yard waste and other junk at the time. Not sure if that triggered it or not... So right away I changed the speed sensor on the rear diff... that is usually the cause plus it's only a 15 dollar part and 10 minutes to change out so I figured why not. The light is still on. So I go to my local Advanced Auto (where I bought the sensor from) and I get a free scan. According to their scanner, both front wheel speed sensors AND the rear sensor on the diff (which I just replaced) are bad. Does this sound right? I've heard a low battery can sometimes trigger the ABS light too. The truck continues to drive perfectly normal like nothing happened. Brakes, speedometer, cruise, etc. EVERYTHING still works perfect. Just got that damn light on... so what say you FTE? sorry for the long ramble...
Old Apr 18, 2013 | 05:07 AM
locknload223's Avatar
locknload223
I went and am going through the same thing. Light came on, I changed the rear sensor, light still on. Hooked up Auto Enginuity and it said both front sensors are bad. I checked the wiring harnesses and they looked fine. Everything works so I've just ignored the light until I pick up some new sensors... or a little square piece of electrical tape .
Old Apr 18, 2013 | 05:10 AM
drey04's Avatar
drey04
Thanks for the quick response locknload223 I need to do my front brakes soon anyway so when I have it apart I'll check them out. Yeah this is the first time EVER I've had any type of check light pop up on my dash so it's bugging the crap outta me lol
Old Apr 18, 2013 | 05:14 AM
locknload223
While you're down there, replace the vacuum line that runs next to the ABS wires. It's should be dry rotted and nasty. Can't remember the size just bring a little piece into the parts store and they'll set you up.
Old Apr 18, 2013 | 05:31 AM
drey04's Avatar
drey04
I've got manual hubs so my vacuum lines are unhooked and zip-tied up
Old Apr 20, 2013 | 04:09 PM
the_justin's Avatar
the_justin
Just got my 2012 F350 DRW out of the shop for ABS light as well. ABS and traction control lights on the dash cluster were permanently illuminated. Took it in and they told me it was some sort of speed sensor in the front right wheel area. Fixed under warranty, no more lights.
Old Apr 26, 2013 | 03:19 PM
drey04's Avatar
drey04
Well... it ended up being the passenger side front sensor. No more ABS light
Old Apr 26, 2013 | 04:36 PM
acf6's Avatar
acf6
Nice fix. I had the left one go on my old truck, but it didnt throw a light/code. It just would pulse bad when stopping
trober_603
1997 - 2003 F150
May 20, 2012 11:00 PM
Strokin-8
Oct 9, 2010 02:26 PM
dogman
Feb 28, 2006 06:01 PM
FlyinFord
May 23, 2005 04:41 PM
gvmann
Sep 25, 2003 07:37 PM
