Sponsored by: Real Truck
99 electrical please help
Old May 14, 2013 | 05:43 AM
redford's Avatar
redford
FTE Leadership Emeritus
Your speedometer gets a reading from the VSS sensor, on the rear differential. Was it bouncing or showing any odd symptoms before it stopped working?
Old May 15, 2013 | 11:06 AM
98rangerll's Avatar
98rangerll
In the past over six months ago the speedo would some times jump around or not work at all but then I did dielectric the speed out put sensor and had the code reset and hadn't had any trouble again until I found the problem with the fuse box and now its just doing nothing and I'm wondering if I got another bad connection or a broke wire or worse and if you all might have a idea thanks guys
Jclaytonk
Aug 31, 2017 12:17 PM
FordTruckEnthusaist
Feb 14, 2014 08:46 AM
MrProdigious
Aug 4, 2013 06:36 PM
vampirefish
Nov 23, 2010 04:32 PM
4inchlovin
16
Mar 17, 2009 09:15 AM
